moth175 Posted May 22, 2005 Report Share Posted May 22, 2005 My 1999 TDi has a climatronic unit but although the fan is switched on it only actually comes one when it wants, maybe once a week if i'm lucky Any ideas welcome Link to comment Share on other sites More sharing options...
felixthecat1 Posted May 22, 2005 Report Share Posted May 22, 2005 Does it light up when it's not working? Have you fitted anything else in the car that might be affecting it? Have you noticed any pattern to when it actually works? Have you checked the fuses? Perhaps it's just not seated properly. If it doubt ask Wobby. He be da man. Seriously. Link to comment Share on other sites More sharing options...
moth175 Posted May 23, 2005 Author Report Share Posted May 23, 2005 It still lights up and displays all features but theres not air coming out. All the fuses are in working order Thanks Link to comment Share on other sites More sharing options...
Wobby Posted May 23, 2005 Report Share Posted May 23, 2005 Hi, Tian.... Are you making fun of me !!! Link to comment Share on other sites More sharing options...
Wobby Posted May 23, 2005 Report Share Posted May 23, 2005 Maybe check the wires to the fan first. Might be a loose wire or maybe you are in need of a new fan I can (over the weekend) get some readings off the relevant pins on my climate control and post them if it will help. Might eliminate a fault with the climate control RobK Link to comment Share on other sites More sharing options...
felixthecat1 Posted May 23, 2005 Report Share Posted May 23, 2005 [ QUOTE ] Tian.... Are you making fun of me !!! [/ QUOTE ] No mate, you should know me better than that by now. Everything's cool. Link to comment Share on other sites More sharing options...
moth175 Posted May 24, 2005 Author Report Share Posted May 24, 2005 that would be great if you get chance Link to comment Share on other sites More sharing options...
Waitey Posted May 24, 2005 Report Share Posted May 24, 2005 Hi Moth it couldnt be something to do with the problem you had with interior lights could it, do the wires for climate run in same place? Just a thought. Link to comment Share on other sites More sharing options...
moth175 Posted May 24, 2005 Author Report Share Posted May 24, 2005 Hi, i thought that too but according to the manual the climate control isn't governed by the convenience unit Thanks though Link to comment Share on other sites More sharing options...
M8CKN Posted June 1, 2005 Report Share Posted June 1, 2005 My 2000 Passat did this. Like I had a ghost in the car, as started to work when it wanted!! Needed new A/C compressor and blower motor. Link to comment Share on other sites More sharing options...
meriafel Posted June 3, 2005 Report Share Posted June 3, 2005 Sounds like intermittent blower motor. Mine is the same, is under warranty and in next week for a new one. Works one day, not the next, will stop/start during journey. Showed up on VAG-COM. Check that your air-con feed pipes under bonnet are cold and to see if compressor is OK. Will post results of repair on site when it's done. Had hernia op yesterday (ouch!) so blower won't be fixed until next week. Link to comment Share on other sites More sharing options...
moth175 Posted June 3, 2005 Author Report Share Posted June 3, 2005 feed pipes under bonnet are cold, i'll try and locate the blower motor and replace it, see if it cures the problem, thanks Link to comment Share on other sites More sharing options...
M8CKN Posted June 4, 2005 Report Share Posted June 4, 2005 Try www.volkswagenspares.com or www.volks-apart.com (same place) if you need a blower motor, they were cheapest by far when I needed one and got it too me within 24 hours. Link to comment Share on other sites More sharing options...
moth175 Posted June 4, 2005 Author Report Share Posted June 4, 2005 I'll give them a go, is it easy to locate/remove? Thanks Link to comment Share on other sites More sharing options...
Wobby Posted June 4, 2005 Report Share Posted June 4, 2005 Yeah, but it would be best to investigate the motor already fitted to see if it is faulty, if your getting a voltage to power it and its not responding then it will be the motor/ blower. RobK Link to comment Share on other sites More sharing options...
meriafel Posted June 14, 2005 Report Share Posted June 14, 2005 As promised said I would report outcome of my intermittent air-con. Sure enough it was a faulty blower motor and replaced under the third years warranty. It was actually working when the car was taken in for repair but was replaced as the VAG-COM print-out had confirmed it was faulty. Understand the cost of the blower as a unit was approx £250 plus Vat and fitting! How did you get on ? Link to comment Share on other sites More sharing options...
Wobby Posted June 15, 2005 Report Share Posted June 15, 2005 Hi, Moth... how did you go with it?? Sorry i havn't been able to post some readings like i said i would. I was going to get the readings when i installed my sat nav, the install was very difficult and took much more time. I moved my climate control when i modified the dash, so i thought i could get readings while it was in bits. Time never allowed, sorry. Post if you are still having problems. Thanks RobK Link to comment Share on other sites More sharing options...
