byron13 Posted May 23, 2005 Report Share Posted May 23, 2005 Folks - Got satnavsytems to fit this at the weekend and it is great and am very impressed with the system. One quick question to those who have this with colour DIS. Do you or should you have the navigation symbols coming up on the DIS? At the moment it is not doing this but Satnavsystems people did not know off the top of their heads how to do this. They are going away to check and will come back to do this later. Just thought I would ask if any of the SAT NAV experts on here know what they need to do to get this working? I guess it is a coding thing with VAG COM? Also I recall a warning that BOSE does not always work correctly after this install! Any idea how I can check as my ears prob can not tell the difference. It does sound good but prob not as "loud" as the old Symphony with BOSE. Thanks all. Link to comment Share on other sites More sharing options...
Chav Posted May 23, 2005 Report Share Posted May 23, 2005 i thought it was the same CANBUS connection regardless of whether its a colour or mono dis? Link to comment Share on other sites More sharing options...
byron13 Posted May 23, 2005 Author Report Share Posted May 23, 2005 Thanks Chav Might be a different code, just don't know? Link to comment Share on other sites More sharing options...
rjgreen4 Posted May 23, 2005 Report Share Posted May 23, 2005 I had a similar problem when satnavsystems installed the RNS-E in my 4, I went over to Craigyb's and he pulled out my RNS-E and found that the Bose had not been wired into the Rns-e, therefore not really using the bose properly, he also used vag.com to change the wheel/tyre size that had previously been programmed in as it was thinking that the car had 16" rims, when it should have been 18", could make a difference on long journeys etc. Not sure about the DIS as I have not got it on my car and therefore have to rely on the maps shown on screen. I am 95% sure that the RNS-E send a picture with the turning directions to the dash. Cragyb also found that the old (2004 version)sat nav dvd needed to be updated to the 2005 version for the mute function to be enabled for hands free kits, worth taking note if you want a parrot hands free or similar system to go through the RNS-E. We enabled the mute function with vag.com, utilising all the possible codes but for some reason it would not work with the 2004 software, worked with the updated 2005. Drop cragyb an IM, he knows his stuff and should be able to help. Link to comment Share on other sites More sharing options...
byron13 Posted May 23, 2005 Author Report Share Posted May 23, 2005 Thanks Rigreen I read your original woes and specifically mentioned them to SatNav people to try and stop this. I pressume that when BOSE was not wired in it still sounded ok? Just wondered if you could tell when it was working. Anything change on the RNS-E that I could check. Craigb has kindly responded with some advice. Link to comment Share on other sites More sharing options...
rjgreen4 Posted May 24, 2005 Report Share Posted May 24, 2005 we also changed the coding on the RNS-E to send the guidance voice through the right hand side speakers as they previously came through the left, pressume it was set up for a left hand drive car. I don't recall the Bose being much different, but it definitely was not plugged in. The wiring was a bit of a mess after satnav systems had finished but i was not going to complain as the company paid for the nav and they drove from london to Cheshire to install it. Currently looking for a decent tv tuner, any ideas? Link to comment Share on other sites More sharing options...
byron13 Posted May 24, 2005 Author Report Share Posted May 24, 2005 Thanks Rigreen - waiting on a response from them about the DIS and BOSE etc. Bit woried that they do the same install every time (ie same as yours). I mean it does work but I paid for a pro install so it worlks 100% not 95% which is what it would have been like if I had fitted it. Sorry no idea about TV tuners etc as still learning about th basic NAV! Link to comment Share on other sites More sharing options...
richyA3 Posted May 24, 2005 Report Share Posted May 24, 2005 wouldn't bother about Tv options on the cars.. The anologue signal is going to be swtiches off in thenext year or so and to be honest is never a great picture anyways. Link to comment Share on other sites More sharing options...
Big_Dan Posted May 24, 2005 Report Share Posted May 24, 2005 2010 for the analogue switchoff across most of Europe, but whether it happens or not is a different matter. Link to comment Share on other sites More sharing options...
cosmicblue Posted May 24, 2005 Report Share Posted May 24, 2005 [ QUOTE ] One quick question to those who have this with colour DIS. Do you or should you have the navigation symbols coming up on the DIS? [/ QUOTE ] I have the DVD Navigation with the Colour DIS, yes you do get navigation system 'pictogram' symbols on the DIS display. Also shows data that isn't shown in the Nav-head unit such as a Red bar that decreases in length as you get closer to a turn - and exactlly which road you are on when the Nav system isn't following a preogrammed route/destination. MP3/Radio/Cd stuff is also shown. The stalk button that cycles through the Trip computer modes has 4 'top screens': the 1st is Navigation, the 2nd is Blank save for the autobox 'gate' at the bottom (I suspect that this is for the factory fit mobile phone integration) the 3rd is Trip Comp 1 the 4th is Trip Comp 2 The Nav system is brilliant - just wish Audi would get its finger out and make the TMC data disks available. Link to comment Share on other sites More sharing options...
byron13 Posted May 25, 2005 Author Report Share Posted May 25, 2005 Thanks cosmic blue. Got to get them back to fix anyway as the battery was flat this morning so wonder what they wired in wrong !! Link to comment Share on other sites More sharing options...
gizze Posted May 25, 2005 Report Share Posted May 25, 2005 I don't see how they can bugger it up really, all the adapters out there will show them how to wire it, and the codes are all over the net for when they plug the vag-com in as well. Link to comment Share on other sites More sharing options...
craigyb Posted May 25, 2005 Report Share Posted May 25, 2005 Maybe I should supply installs myself!!! how about it guys? A3, A4 and A6, plus custom S8/A8 installs. All wiring done with latest disk and Vagged for your car. £1000 If I'm advertising, delete this post I just think I can do a better job than Satnavsystems. Craig Link to comment Share on other sites More sharing options...
byron13 Posted May 25, 2005 Author Report Share Posted May 25, 2005 Craigb - would have been well up for that, I got worried on ebay getting the unit to start with. You should do though as I am sure lots of people would jump at the chance. Have to retract the flat battery issue I think as Audi came out late this afternoon and it looks as if I might have left the map light on the other night!! In the Garage on Charge now and Satnavsystems coming out tommorow at 5 to solve the DIS issue (I hope) and check that BOSE is connected. I had my first look at VAG COM tonight (proper Ross Tech ones borrowed from a friend) and have to admit can't see what I would have to do?? Any hints Craigb or Gizze, just in case Satnavsystems can't crack it tomorrow. It would be nice to "guide" them eh. Happy to compensate with delivery of backup copies of usefull VAG software. Link to comment Share on other sites More sharing options...
gizze Posted May 25, 2005 Report Share Posted May 25, 2005 You really should go for it Craig, there are loads of people that would be up for it, I have had loads adk me to do it too, but I just don't have the time, but I would love to be able to point them in the direction of someone who really knows what they are doing. byron13, print out this and give it to them.... {radio/navigation system (RNS e)} Note: With the RNS e in address 37 and 56 the same controller, no difference between address 37 and 56 exists reacted. Controller coding STG 56 (radio/navigation system) select STG coding - > function 07 0?xxxxx: Vehicle 1 - AUDI a2 2 - AUDI A3 (8P) 3 - AUDI A4 (starting from MJ 2004) 4 - AUDI A4 Cabriolet (starting from MJ 2004) 5 - AUDI A6 (to MJ 2004) 6 - AUDI TT (starting from MJ 2004) 0x?xxxx: Fault-tracing 0 - Fault-tracing for front loudspeakers actively 1 - Fault-tracing for front loudspeakers inactively 0xx?xxx: Sound characteristic 0 - linear sound characteristic 1 - AUDI A4 (starting from MJ 2004) 2 - AUDI A6 (to MJ 2004) 3 - AUDI A4 Cabriolet (starting from MJ 2004) 4 - AUDI TT (starting from MJ 2004) 5 - AUDI A3 (8P) 9 - Bose sound system 0xxx?xx: Telephone/telematics 1 - no telephone (supply voltage for microphone actively) 2 - Mobile phone preparation (Temic - Speisesp. Microphone inactively) 3 - Mobile phone preparation (Cullmann - Speisesp. Microphone inactively) 4 - Mobile phone preparation (Nokia - Speisesp. Microphone inactively) 5 - Telematics Europe (supply voltage microphone inactively) 6 - Telematics US (supply voltage microphone inactively) 0xxxx?x: Austattungsoptionen I 1 - no additive zusatz-Tuner 2 - Digital radio 3 - Satellite radio 4 - Satellite and digital radio block 0xxxxx?: Austattungsoptionen II 1 - no TV tV-Tuner, CD change-over switch or multi-function steering wheel 2 - TV tV-Tuner available 3 - CD change-over switch available 4 - TV tV-Tuner and CD change-over switch available 5 - Multi-function steering wheel available 6 - TV tV-Tuner and multi-function steering wheel available 7 - CD change-over switch and multi-function steering wheel available 8 - TV tV-Tuner, CD change-over switch and multi-function steering wheel available Controller adjustment STG 56 (radio/navigation system) select STG adjustment - > function 10 - > channel 001 (tire extent in mm) See tire extent table. - > channel 002 (impulse number/wheel revolutions - GALA) The value 0 calibrates themselves the system after some kilometers themselves registered and registers automatically the correct value. 43 - AUDI A3 (8P) 45 - AUDI A4 (starting from MJ 2004) - > channel 003 (indicator language) Over this channel the screen language is adapted. 0 - German 1 - English (UK - NOT North America) 2 - French 3 - Italian 5 - Spanish 7 - English (US - ONLY North America) - > channel 005 (TV disconnection) 0 - Disconnection while stationary 1 - Disconnection over 5 km/h - > channel 007 (extended attitudes) +01 - Distance unit (miles) +02 - Speed unit (mph) +04 - Time format (12h) +08 - Format of date (MM:TT:JJJJ) +16 - Repetition of the Sprachbedieungs commands - > channel 008 (GALA function) 000 - GALA function switched off 001 - Characteristic 1 002 - Characteristic 2 003 - Characteristic 3 004 - Characteristic 4 005 - Characteristic 5 255 - GALA over angeschl. Microphone - > channel 010 (region) 0 - Northern Hemisphere 1 - Southern Hemisphere - > channel 065 (read test) The values are not durably gespechert and to serve only for starting the jeweligen test. 1 - Short test start 2 - Read test start (more exact examination) - > channel 066 (self check) For starting you test/store self check the value 1. The values are not durably gespechert and to serve only for starting the jeweligen test. Thereby the following components are gestest: DVD, government inspection department receiver, government inspection department antenna, Gyro, key, status internal interface, communication to the doing he module, CAN bus chip, map reader 1 & 2, loudspeakers passively, radio antenna, DSP tension, microphone - > channel 067 (CD/DVD ejection) 000 - Normal status 001 - CD/DVD eject (one does not store) 255 - Eject button closed (theft protection) - > channel 068 (test pattern) The values are not durably gespechert and to serve only for starting the jeweligen test. 0 - no test pattern 1 - Test pattern red 2 - Test pattern green 3 - Test pattern blue 4 - Test pattern white 5 - Test pattern black 6 - Test pattern chessboard 7 - Test pattern chessboard (inverts) 8 - Test pattern 64 gray tones (vertical bars) 9 - Test pattern special - > channel 069 (display mechanism) 000 - Display closed 001 - Display openly 200 - Display half-open (obstacle) 255 - undefined position - > channel 070 (display brightness) 0 - switched off 1 - 20 % brightness 2 - 40 % brightness 3 - 60 % brightness 4 - 80 % brightness 5 - 100 % brightness - > channel 099 (transportation mode) This channel is used only with vehicles without CAN gateway. 0 - Transportation mode inactively 1 - Transportation mode actively - > channel 111 (system RESETS) With store the value 1 a system restart one introduces. The controller herungergefahren is again started and. Error memory of entries is not cleared thereby. - > channel 114 (FM transmitter attitude) On request. - > channel 117 (signal position) Adjustment of the signal output on the individual loudspeakers. 0 - Fader center - balance center 1 - Fader in front - balance left 2 - Fader in front - balance right 3 - Fader in the back - balance left 4 - Fader in the back - balance right - > channel 136 (navigation references) Adjustment of the Laenderasfuehrung concerning the acoustic navigation references to the driver position. 00005 - Link steering wheel (US) 00013 - Right steering wheel (the USA) 02632 - Right steering wheel (Europe) 03226 - Link steering wheel (Europe) {tire extent table} 1790 - 145/80 R14 (summer tire) 1815 - 165/65 R15 (summer tire) 1803 - 175/60 R15 (summer tire) 1806 - 185/50 R16 (summer tire) 1935 - 195/65 R15 (summer tire) 1910 - 205/60 R15 (summer tire) 1930 - 205/55 R16 (summer tire) 1818 - 205/40 ZR17 (summer tire) 1960 - 215/55 R16 (summer tire) 2060 - 225/60 R16 (summer tire) 1930 - 225/45 R17 (summer tire) 2074 - 225/55 R17 (summer tire) 1943 - 225/40 ZR18 (summer tire) 1960 - 235/50 R16 (summer tire) 1964 - 235/45 R17 (summer tire) 1967 - 235/40 ZR18 (summer tire) 2065 - 245/45 R18 (summer tire) 2065 - 245/45 ZR18 (summer tire) 1940 - 255/40 R17 (summer tire) 1937 - 255/35 R18 (summer tire) 1937 - 255/35 ZR18 (summer tire) 2016 - 255/40 ZR18 (summer tire) 2016 - 255/35 ZR19 (summer tire) 2092 - 255/35 ZR20 (summer tire) 1775 - 155/65 R15 (winter tire) 1895 - 185/65 R15 (winter tire) 1935 - 195/65 R15 (winter tire) 1930 - 205/55 R16 (winter tire) 1960 - 215/55 R16 (winter tire) 2092 - 215/65 R16 (winter tire) 2060 - 225/60 R16 (winter tire) 1930 - 225/45 R17 (winter tire) 2070 - 225/55 R17 (winter tire) 1940 - 225/40 R18 (winter tire) 2010 - 225/45 R18 (winter tire) 2040 - 235/45 R18 (winter tire) 2114 - 235/50 R18 (Winterreifenn) 1940 - 255/40 R17 (winter tire) {telephone} Controller coding STG 77 (telephone) select STG coding - > function 07 ?xxxx: Data bus 0 - with data bus 1 - without data bus x?xxx: Motor vehicle type 0 - A3 (OFF) 1 - A4 (B5) 2 - A6 (C5) 3 - A8 (D2) 4 - a2 (W10) 5 - A4 (B6) xx?xx: Language operating/multi-function steering wheel (SBS/MFL) +0 - without SBS, without MFL +1 - MFL +2 - SBS xxx?x: Navigation system 0 - without Navi 1 - with Navi III 2 - with Navi II-D 3 - with Navi IV xxxx?: Type of radio 1 - without radio 2 - with radio (with CAN - Symphony I/II, Chorus/Concert II) 3 - with radio (with CAN - Symphony I/II, Chorus/Concert II) with Bose 4 - with radio (without CAN - Chorus/Concert/Symphony I) or Navi II-D 5 - with radio (without CAN - Chorus/Concert/Symphony I) or Navi II-D with Bose Controller adjustment STG 77 (telephone) select STG adjustment - > function 10 - > channel 5 (antenna test) The function antenna test is not available after past realization in all controllers. 0 - no test 1 - Gs one threshing floor is tested (cannot be used if necessary) {telephone (mobile phone preparation)} Controller coding STG 77 (telephone) select STG coding - > function 07 HU = Head unit (e.g. RNS D/E) MFL = multi-function steering wheel ?xxxx: Motor vehicle type 0 - Fahrzege with CAN data bus (a2, A3, TT) 1 - D3/C6 High system 2 - C6 standard system x?xxx: Type of steering wheel 0 - no multi-function steering wheel 1 - Unit steering wheel 2 - Modular steering wheel xx?xx: Sheeting list 1 - no MFL/HU/K line 2 - MFL 3 - HU 4 - MFL and HU 5 - K-line (diagnosis) 6 - MFK and k-line 7 - HU and k-line 8 - MFL, HU and k-line xxx?x: Language for language operation 0 - Language operation out 1 - German 2 - English (UK) 3 - Franzoesich 4 - Italian 5 - Spanish 7 - English (US) 8 - Language operation of external equipment (e.g. RNS e) 9 - Speaker-dependent language choice xxxx?: Language for announcement in the combination instrument 0 - no announcement in the combination instrument 1 - German 2 - English (UK) 3 - French 4 - Italian 5 - Spanish 7 - English (US) Controller adjustment STG 77 (telephone) select STG adjustment - > function 10 - > channel 128 (basic volume) Basic volume of the output signal. 000 - 0dB (no rise/sinking) 001 - +1dB rise 003 - +3dB rise 006 - +6dB rise 128 - -1dB sinking 130 - -3dB sinking 133 - -6dB sinking - > channel 129 (hunting time) Hunting time of the mobile phone preparation after ignition out 000 - 30 seconds of hunting time 001 - 5 minutes of hunting time 002 - 10 minutes of hunting time 240 - 20 hours of hunting time - > channel 130 (deceleration time) Deceleration time of the audio components for the compensation of acoustic running times (avoidance of echoes). Range of values: 0 - 12 ms - > channel 131 (microphone sensitivity) Lower/raise the microphones sensitivity. 000 - 0dB (no rise/sinking) 001 - +1dB rise 002 - +2dB rise 003 - +3dB rise 004 - +4dB rise 005 - +5dB rise 006 - +6dB rise 128 - -1dB sinking 129 - -2dB sinking 130 - -3dB sinking 131 - -4dB sinking 132 - -5dB sinking 133 - -6dB sinking - > channel 133 (Bluetooth) Bluetooth activate/deactivate. - > channel 134 (free speech function) 0 - Acquit also without inserted mobile phone over Bluetooth 1 - Acquit only with inserted mobile phone - > channel 135 (Bluetooth PassKey) Standard: 1234 - > channel 136 (deceleration time) Deceleration time between signal and language request clay/tone adjusted (dependent on the radio system). 001 - 0.1 seconds 002 - 0.2 seconds ... 025 - 2.5 seconds {telematics} Controller coding STG 75 (telephone/telematics) select STG coding - > function 07 0?xxx: Motor vehicle type 0 - A3 (OFF) 1 - A4 (B5) 2 - A6 (C5) 3 - A8 (D2) 4 - a2 (W10) 5 - A4 (B6) 0x?xx: Language operating/multi-function steering wheel (SBS/MFL) +0 - without SBS, without MFL +1 - MFL +2 - SBS 0xx?x: Navigation system 0 - without Navi 1 - with Navi III 2 - with Navi II-D 3 - with Navi IV 4 - with Navi II-D (starting from KW of 45/01) 5 - with Navi IV (starting from KW of 45/01) 0xxx?: Type of radio 1 - without radio 2 - with radio (with CAN - Symphony I/II, Chorus/Concert II) 3 - with radio (with CAN - Symphony I/II, Chorus/Concert II) with Bose 4 - with radio (without CAN - Chorus/Concert/Symphony I) or Navi II-D 5 - with radio (without CAN - Chorus/Concert/Symphony I) or Navi II-D with Bose Controller adjustment STG 75 (telematics) select STG adjustment - > function 10 - > channel 01 (tire extent in mm) See tire extent table. - > channel 02 (impulse number of the ABS sensors) 08 - AUDI A6, A8, TT 39 - AUDI a2 (1,2 Oeko) 43 - AUDI a2 (except 1.2 Oeko) 45 - AUDI A3, A4 - > channel 03 (service mode) After clamping the automotive battery the controller switches immediately to stand-by battery. If longer time is the case, the stand-by battery discharges and must be replaced (error code: 01531). If the service mode is activated, then the controller switches not to stand-by battery. After completion of the service work the service mode is to be deactivated again. The service mode can be activated and deactivated also by input of * # 4610 # at the control listener. 0 - Service mode deactivates 1 - Service mode activates - > channel 05 (antenna test selection) 0 - no test 1 - GSM Hauptantenne is tested 2 - GSM gSM-Notantenne is tested 3 - both gs one threshing floors are tested - > channel 06 (antenna selection) 0 - automatic selection 1 - GSM Hauptantenne selected 2 - GSM gSM-Notantenne selected - > channel 07 (system choice) Over this channel the Teleatikfehlermeldungen can be deactivated at expiration of the telematics service contract, the telephone stands thereafter further as fixed installation telephone for the order (only with new SIM map). 0 - Normal operation 1 - Error messages suppress {TV tV-Tuner} Controller coding STG 57 (TV tV-Tuner) select STG coding - > function 07 0?xxx: Diagnostic introduction 0 - does not occupy 1 - Wake only over CAN possible 2 - Wake only over k-line possible 3 - Wake over CAN and k-line possible 0x??x: Land coding/video standard 00 - does not occupy 01 - PAL B/G (MID EUROPE) 02 - PAL B/G (ITALY) 03 - PAL I (UK, IRISH COUNTRY) 04 - SECAM D/K (EAST EUROPE) 05 - SECAM L (FRANCE) 06 - NTSC M (NORTH AMER.) 07 - PAL B/H (AUSTRALIA) 10 - PAL M (BRASILIA) 11 - PAL N (ARGENTINA) 12 - PAL B (NEW ZEALAND) 13 - PAL D/K (CHINA) 14 - PAL I (AFRICA) 15 - SECAM D/K (GREECE, EGYPT) 16 - SECAM K1 (AFRICA) 17 - NTSC M (JAPAN) 0xxx?: Tunerkonfiguration for the secondary display 0 to 3 - component does not block 4 to 7 - component blocks Link to comment Share on other sites More sharing options...
craigyb Posted May 26, 2005 Report Share Posted May 26, 2005 I appreciate that guys, if you do now anybody that is interested in a sat nav, let me know. Craig Link to comment Share on other sites More sharing options...
byron13 Posted May 26, 2005 Author Report Share Posted May 26, 2005 Gizze - thanks mate that is great. Hope it might make sense to me one day!! Link to comment Share on other sites More sharing options...
UBM Posted May 26, 2005 Report Share Posted May 26, 2005 Yeah - good idea! It would be interesting to know how much you would charge and what you would get. For instance, would you supply everything, be prepared to travel etc? Link to comment Share on other sites More sharing options...
craigyb Posted May 26, 2005 Report Share Posted May 26, 2005 I think the charge would be for an RNS-E unit, 2005 disk, GPS receiver (if needed), all adaptors needed for the install. VAG coded to suit your car. No TV upgrade, that would be extra if you had a tuner fitted already. So I could say the following will work after an install, Radio/NAV - CD changer/DIS/Telephone (if fitted). TV tuner upgrades are straight forward, but finding the tuner for the right price is tricky. I could travel withtin reason, but I would prefer most people to come to me as I have quite extensive workshop, but no covered area I'm afraid. Craig Link to comment Share on other sites More sharing options...
byron13 Posted May 26, 2005 Author Report Share Posted May 26, 2005 Ok we have got the bose working the K line connected and all the setting that Craigb mentioned done, just can not find the codes for the cluster. Gizze - your list was great but think Ineed one for the cluster - don't suppoose anyone has the same for the instruments as we can not get the 4 options in the DIS that Cosmic mentions. Thanks to all Link to comment Share on other sites More sharing options...
byron13 Posted May 26, 2005 Author Report Share Posted May 26, 2005 Update - this is what was done. (I think!) "Try coding channel 62 to 21 (mine was 17 w/o Nav)" Got this from Audi world. Needed the key taking out and putting back in for it to work. We had given up for tonight but just been out to the car and it works fine. I like the arrows and distance measure to junction. I also like the fact that it tells you what road you are on even if you are navigating to anywhere. Thanks all. I now sort of understand Vag Com codes. Byron Link to comment Share on other sites More sharing options...
