ozzy11 Posted April 29, 2003 Report Share Posted April 29, 2003 i have a 1988 audi 5000 s, my problem is this.My passenger side window will go down using the passenger side control, but not up.It will not move either way using the driverside control.I replaced the controls on both sides with no luck. And was told that if the motor was gone,it wouldn`t work at all.Any help is much appreciated. Link to comment Share on other sites More sharing options...
peterb Posted April 29, 2003 Report Share Posted April 29, 2003 I would check out the wiring where it passes from the car body to the door (I assume that the passenger side control is actually mounted on the door). Link to comment Share on other sites More sharing options...
ozzy11 Posted April 29, 2003 Author Report Share Posted April 29, 2003 thanks peter i`ll try checkin that out for sure,I probably should have posted in the technical forum huh? any moderator want to move this thread for me? Link to comment Share on other sites More sharing options...
