RS4_Barry Posted July 25, 2005 Report Share Posted July 25, 2005 Not been on for ages a couple of the scottish tyresmokers had phoned me up to see if I was still alive - I am but I have been enjoying this for the last couple of weeks. Pretty cool huh? Link to comment Share on other sites More sharing options...
Dave Posted July 25, 2005 Report Share Posted July 25, 2005 Yea.. some of the old stuff is real fun.. I'm liking cars that you can push to the limit and are still only doing 60!! Link to comment Share on other sites More sharing options...
RS4_Barry Posted July 25, 2005 Author Report Share Posted July 25, 2005 Yeah but this is quite a manly 120ish bhp mini - and it will do silly speeds Link to comment Share on other sites More sharing options...
Dave Posted July 25, 2005 Report Share Posted July 25, 2005 LOL.. i should of known it wasn't unmolested Link to comment Share on other sites More sharing options...
felixthecat1 Posted July 25, 2005 Report Share Posted July 25, 2005 I love that car, good to see your avatar back again too. What are the chances of me fitting in a mini and coming out without back trouble? Link to comment Share on other sites More sharing options...
RS4_Barry Posted July 25, 2005 Author Report Share Posted July 25, 2005 Getting in's easy it's getting out ..... oooyah it's hard. Link to comment Share on other sites More sharing options...
Ritey Posted July 25, 2005 Report Share Posted July 25, 2005 Lovely piece of work, got the specs? How much did you pay for it if you don't mind me asking? Link to comment Share on other sites More sharing options...
RS4_Barry Posted July 25, 2005 Author Report Share Posted July 25, 2005 Exterior Miglia wide open weave carbon fibre arches Full respray in Rover diamond white with black roof Rear arches cut back 3 inches to fit 13" wheels Front arches cut to take 13" wheels SPA carbon fibre F1 door mirrors Iridium lense headlights Clear front indicator lenses Clear side repeaters Chrome front grille Stainless steel bumpers One piece clear rear light clusters with integral fog light Curley mouldings fibreglass bonnet with red quick release pins Chrome washer jets, escutchions and wipers New door handles all round Interior Cobra New clubman seats with red and black trim Luke 4 point harnesses with aircraft turnbuckles Curley carbon fibre dashboard with custom dial mounts in polished alloy Full FIA spec bolt in roll cage with door bars fitted and all round fire retardant padding SPA designs digital speedometer Stack 10.5 k rev counter with shift light Oil pressure / water temp and fuel gauges (Smiths) KAD new style lift up reverse quickshift Red leather gear gaitor Sparco safari steering wheel on Snap off removable mount Flat black door cards all round Alloy door furniture New cream roof lining Fire extinguisher mounted to roll cage Heater system removed to save weight New black carpets (Underlay removed to save weight) Custom interior wiring loom with Rover connectors fitted all round Suspension Front and rear 16 point adjustable AVO shocks Front and rear Hilos Front and rear adjustable camber (front rose jointed adjustable) Front rose jointed adjustable tie rods Late model suspension cones Solid mounted sub frames front and rear Rear anti roll bar (not fitted but can be in 15 minutes) Brakes KAD 4 pot alloy front callipers Pagid grooved vented 8.4 inch discs Pagid fast road pads KAD twin master cylinder pedal box with adjustable bias (master cylinders matched to brakes fitted) Brake bias lock (ap racing not fitted) Brake pedal box bias adjuster (incar adaptor from KAD) KAD alloy rear handbrake quadrants Handbrake moved back by three inches inside car Braided hoses all round (besides front to back of car to maintain pedal pressure) Wheels and tyres 13 x 7" superlites Yokohama A008 tyresTransmission Jack Knight 4 speed straight cut gearbox (Close ratio with very long first gear, ideal for track use) 1:1.1 straight cut close ratio transfer gears Engine WFM1024 injection cooper block, bored to 1380 cc (by Swiftune racing) Omega dished pistons on lightened balanced cooper rods Cross drilled, wedged, bladed, lightened and balanced crank 296 Kent cam Duplex vernier timing gear Swiftune racing Rallysprint head and custom matched inlet manifold Twin modified 1.25 inch SU carbs with Ramair ram pipes and filter socks Superlight steel flywheel and triangulated steel backplate AP racing organic turbo clutch plate with Grey diaphragm Swiftune prepared distributor matched to head and cam charecteristics 1.5:1 ratio full roller rockers Facet red top fuel pump LCB manifold, wrapped in thermal insulation Play mini straight through center section Play mini carbon tech back box High capacity oil and water pumps Platinum NGK race plugs Magnecore 8mm silicone HT leads Lucas sports gold coil Reworked wiring loom Alloy rocker cover and T-bars 2 core radiator Upper and lower ultimate engine steadys (Miglia spec also supplied) 13 row oil cooler with braided hoses Fuel regulator and additional glass filter Braided clutch hose K and N breather filters That about covers it! It's got some serious receipts with it too! Link to comment Share on other sites More sharing options...
RS4_Barry Posted July 25, 2005 Author Report Share Posted July 25, 2005 sweet! Link to comment Share on other sites More sharing options...
Ritey Posted July 25, 2005 Report Share Posted July 25, 2005 Very nice, would like to see how it goes against my racer Currently building up the KAD online shop for them, see you've got bits already, nice to see. So your having a blast in it, taken it on a track yet? You can really spoil some porka owners day out with beasts like these Link to comment Share on other sites More sharing options...
RS4_Barry Posted July 25, 2005 Author Report Share Posted July 25, 2005 It's pretty awesome flat as feck below 4K and then wham power!!! Love it! Gonna take it along to the next track day after I have sorted out the wheel alignment! Link to comment Share on other sites More sharing options...
Ritey Posted July 27, 2005 Report Share Posted July 27, 2005 Great, have you got more pics? and do you mind me asking what price you paid for said spec ? Link to comment Share on other sites More sharing options...
danksy Posted July 27, 2005 Report Share Posted July 27, 2005 Nice one barry I ran around in a well sorted mini a couple of years back. It had a slark racing engine in it and dyno's at 89bhp at the wheels! Cheers Nick Link to comment Share on other sites More sharing options...
Ritey Posted November 6, 2005 Report Share Posted November 6, 2005 Barry, do you still have the little beast? Link to comment Share on other sites More sharing options...
Jsparkesuk Posted November 6, 2005 Report Share Posted November 6, 2005 Damn that is a beast! Link to comment Share on other sites More sharing options...
jimjammie Posted October 25, 2007 Report Share Posted October 25, 2007 Trying to research the history of this car. Who owned it when, what was done to it, by whom etc etc. It was on E-Bay about a couple of weeks ago. Guy wanted £5,995 for it. He said that it was a rally/sprint/hillclimb car & he was in Somerset. About the only difference I could see was that it's now on 6" rims rather than 7" & it has a small sumpguard. Spec on E-Bay was almost a complete crib from the details supplied by RS4 Barry. Engine bay looks exactly the same. Seller stated that it cost £14,000 to build !! Link to comment Share on other sites More sharing options...
Riz Posted October 26, 2007 Report Share Posted October 26, 2007 Nice car dude..... almost as nice as mine Riz Link to comment Share on other sites More sharing options...
Ritey Posted October 26, 2007 Report Share Posted October 26, 2007 Got a link to the ebay ad or pics, I know a lot of HillClimb minis in the southern region Link to comment Share on other sites More sharing options...
jimjammie Posted October 27, 2007 Report Share Posted October 27, 2007 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...A:IT&ih=008 Not too sure if that link will work & getting pics on here defeats me !! Any info gratefully rec'd Link to comment Share on other sites More sharing options...
Dadstoys Posted October 28, 2007 Report Share Posted October 28, 2007 It looks far better in the top picture than it does on the ebay advert. Link to comment Share on other sites More sharing options...
m4ttm4son Posted November 13, 2007 Report Share Posted November 13, 2007 Looks gorgeous!! Spec sounds amazing too. Link to comment Share on other sites More sharing options...
