size in litres of the petrol tank on a 1.8 audi a4
PAUL982
Surely tank size is irrelevent when budgeting how much you'll spend on fuel. The car doesn't use any more or less cos the tank is bigger or smaller, just changes how often you need to fill it. You'll use whatever you use regardless.
However for the record the current A4 holds 70 litres in 2wd form (regardless of engine size) and the quattro holds 66 litres (but uses more petrol!)
I ran my cab for about 20 miles on Friday with 5 miles showing on the DIS!! When I finally thought I could push it no more I filled up at BP (97 RON - 81.9p/l) and it cost £55.47! So I reckon I had another 10 miles at least left!
