E46 Climate control problem
nstrug330d
Got a weird climate control problem on my 2000 330d Touring and was wondering if there might be an easy fix.
Frequently, the fan will not come on on starting the car, even though the fan display is showing the fan running at full blast. The fan will then come on about 5 minutes later.
Occasionally, the fan will then cut out for a minute or so.
Additionally, even with the a/c on and the temp set to 19.5C, and with cold air blasting out of the dashboard vents, there will be some warm air coming out of the footwell vents.
I've done a little bit of searcing and found various conflicting suggestions (replace capacitor on the climate control PCB etc.)
Be grateful for any suggestions.
Cheers,
Nick
