dblp Posted August 1, 2005 Report Share Posted August 1, 2005 Wotcha, Is it possible to "record" from Sky + to my Laptop? I have a bog std Sky + and a Dell Inspiron 510m lappie. Any idea what hardware and leads I would require. Just want to record the music charts really. Ta Link to comment Share on other sites More sharing options...
Sparky Posted August 1, 2005 Report Share Posted August 1, 2005 If you install an external capture card and connect via S-VHS to your Sky+ box and set the Sky+ box to "COPY" in the Planner you could off-load programmes to your laptop. There are many USB2 capture devices around. All depends on what you want to spend. Link to comment Share on other sites More sharing options...
dblp Posted August 1, 2005 Author Report Share Posted August 1, 2005 Many thanks, Don't want to spend too much - it's not really the video, more of the audio (MTV Dance etc). Any recommendations as to brands of capture device? Link to comment Share on other sites More sharing options...
Snail Posted August 2, 2005 Report Share Posted August 2, 2005 dblp, If all you want to do is record the audio, get a RCA->Headphone cable (£2ish), connect the audio out of your sky+ box with your laptops line-in, then use your music software (itunes, musicmatch, etc) to capture the music. Id recommend capturing in "wav" format, as its fairly easy to edit the bits you dont want out, any other format (MP3, WMV, etc) will have to be converted back to wav before editting anyway. Link to comment Share on other sites More sharing options...
Sparky Posted August 2, 2005 Report Share Posted August 2, 2005 If it's only Audio, could you not just record from the Radio? You can get USB radio sticks for not much ££. Link to comment Share on other sites More sharing options...
