[Audi A3/S3] Can I change the one tyre??
harminder
Hi Guys,
I need to replace my rear drivers side tyre (very close to being illegal).
I asked a freind of mine to change it for me since he works for the AA and has all the equipment neccessary.
My friend advised me that I should not change one tyre but should change them in pairs? He reckons that changing the one tyre can mess up the differential??
Welcome fella,
On 4WD cars it's recommended that you keep all 4 tyres the same, brand, size and spec. Changing one tyre can cause problems as wheels can be rotating at different speeds which will not be good for the diff'. Be safe and visit a specialist.
I personally think you'll ok as long as;
1) The tyres on the axle are the same, and I mean exactly the same.
2) The other tyres aren't too worn. If one is illegal. The likelihood is that others will be too, especially on the same axle.
Don't gamble on stuff like this, it'll just give you a bigger headache in the future.
Good luck
The guy I brought it off changed the passenger side rear for some cheap nasty make.. NONO3.GIF
Others are standard P6000 tyres but all have different levels of grip...
Will this cause any permanent damage........I have done about 3k on them, let alone what the previous owner had done?? SAUER0421.GIF
Without a doubt the tyres I'd recommend are Goodyear F1 GSD3's.
They look the nuts and have great grip. A bit noisy on the road but wet and dry handling / grip are very good.
Strong treadwear rating too at 280. Evo rated them the best tyre too (over Michelins)
Toyo's, Bridgestone, Pirelli are great for grip but wear far too quickly
Michelin Sport Contacts are good too but a bit pricey.
Got to blackcircles.com and they'll quote you but you could find a local dealer to beat the price.
I changed all four 225/45/17 for the F1's at £400 fitted brand new with valves, balancing et al.
Have been looking around for the GSD3's but they are coming in around £450 which at the minute is more than I really want to spend..
Set myself a budget of £300 which means I can pick up some Dunlop SP Sport tyres. I know the grip will not be the same but any views / reviews on the tyres itself?
I have seen some Dunlop SP sport FM901? Any ideas on this specific tyre?
cheapest i found in Cov was Britannia. £464 ish.
Wont be going back there mind you. The cost saving didnt outweigh the wait and traveling
i wouldnt change one tyre, id change two minimum.
i also wouldnt run different tread patterns across an axel.
Changed a single rear tyre on mine a month ago. No problems. The other is around half worn. As long as the size of each (including wear) is not that different then it should not be a problem.
I'd second the F1 recommendation. Good tyres - I pay about £110 for a 225/40x18 at the place round the corner from me.
