scooby_simon Posted August 4, 2005 Report Share Posted August 4, 2005 OK, scooby is going in for a little work, but I cannot find the security key anywhere; Where might I get another one from ? Annoying to say the least.... No idea of the make (Original Scooby prolly) Arse.... Link to comment Share on other sites More sharing options...
Thorburn Posted August 4, 2005 Report Share Posted August 4, 2005 I'd imagine most garages will have the keys for them? I'm quite tempted to ditch my locking wheel nuts as I've seen too many of them snap while being removed. Link to comment Share on other sites More sharing options...
scooby_simon Posted August 4, 2005 Author Report Share Posted August 4, 2005 [ QUOTE ] I'd imagine most garages will have the keys for them? I'm quite tempted to ditch my locking wheel nuts as I've seen too many of them snap while being removed. [/ QUOTE ] Good point; esp as mine are not in the best of nick after nearly 10 years on the road... Link to comment Share on other sites More sharing options...
NeilB Posted August 4, 2005 Report Share Posted August 4, 2005 Worst case senario is they may have to be drilled to remove them. Link to comment Share on other sites More sharing options...
felixthecat1 Posted August 4, 2005 Report Share Posted August 4, 2005 I did mine up too tight not long back and the garage had to remove one by force, didn't take long though, they simply hammered another one on top and used that. Bit of a bugger though, good luck with it. Link to comment Share on other sites More sharing options...
cruiser647 Posted August 4, 2005 Report Share Posted August 4, 2005 Had this with my Audi V8. Went to do something, and the damn securtiy tool was completely shafted. Managed to get them off though, using brute force. They were soooo worn, with the placing bits falling out! ended up buying 4 standard bolts, as the car was 13 yrs old! No bugger would steal those wheels! I think you will have to go to a tyre fitting place and have them 'remove' them Good luck Link to comment Share on other sites More sharing options...
Avus_Bub Posted August 4, 2005 Report Share Posted August 4, 2005 [ QUOTE ] OK, scooby is going in for a little work, but I cannot find the security key anywhere; Where might I get another one from ? Annoying to say the least.... No idea of the make (Original Scooby prolly) Arse.... [/ QUOTE ] Try your Scooby dealer first - they may keep the number on a database or it could be in the service book. If not then most garages these days have special tools to remove them,without too much fuss. One point to remember though - Good quality locking nuts/bolts should last FOREVER. The only reason they get fecked up is because they're over tightened (normally by numpty techs with air guns) HAND TIGHTEN ONLY and you'll never have a problem! BUB Link to comment Share on other sites More sharing options...
scooby_simon Posted August 5, 2005 Author Report Share Posted August 5, 2005 Bolts are sorted; new scooby ones for 20 quid Link to comment Share on other sites More sharing options...
felixthecat1 Posted August 5, 2005 Report Share Posted August 5, 2005 Excellent, not too damaging to the pocket either. Link to comment Share on other sites More sharing options...
scooby_simon Posted August 5, 2005 Author Report Share Posted August 5, 2005 [ QUOTE ] Excellent, not too damaging to the pocket either. [/ QUOTE ] Indeed; but the Turbo issues have (so far) been put down to a fecked Oil filter.... So change of oil, New filter That will be 115 quid please sir.... Link to comment Share on other sites More sharing options...
kevlives Posted August 5, 2005 Report Share Posted August 5, 2005 Do you remember those multi point Socket set that was an all in one ( I think It was called and alligator or something???) It was a 3/8 socket ratchet thingymy - If you can find one of those - from a local pikey market if you have one then you can use those things well handy for when I lost mine ooops Link to comment Share on other sites More sharing options...
felixthecat1 Posted August 6, 2005 Report Share Posted August 6, 2005 [ QUOTE ] That will be 115 quid please sir.... [/ QUOTE ] Ouch, tht's a big hit for something you could do yourself! Link to comment Share on other sites More sharing options...
scooby_simon Posted August 6, 2005 Author Report Share Posted August 6, 2005 [ QUOTE ] [ QUOTE ] That will be 115 quid please sir.... [/ QUOTE ] Ouch, tht's a big hit for something you could do yourself! [/ QUOTE ] Indeed; just time is a major issue for me; I work in the City and so get little enough time at home/playing with the kids/sailing so in terms of hassle vs cash I mindo too much.... Plus I have a bedroom to finish painting etc etc etc.... Link to comment Share on other sites More sharing options...
