2.0L to 2.8L ????
vasfinest
Hey, Ok i was wondering how many other components will I have to change or modify if I choose to swap my 97' Jetta's 2.0L 8v for a Vr6 2.8L engine, If anybody could give any advice on what to do give me a post back thanks,
O yea, and does anyone have any sites where you can buy new VW engines?? If you do email me at [email protected]
Thanks
Don't know about the engines mate, sorry, but you'll definitely need the brakes upgrading unless you want to be spread all over the back of a bus smile.gif
You could probably get the majority of the brake components from a car breakers - there must be quite a few VR6's which have been wrecked over the years (like mine, but fortunately not written-off).
You'll probably also want to upgrade the suspension too - plenty of people offer suspension upgrades, so you shouldn't be short of places to look. If you want to do it on the cheap, you could also try a car breakers for those components too.
At a guess I reckon you'll neeed...
1) New Engine mounts (custom made?) unless your model golf had the 2.8L engine as an option (then the OEM mounts may just work!)
2) New drive shafts (maybe different lengths to the 2.0L and also stronger)
3) New Gearbox (ratios will be different, and internals stronger on the V6)
4) New suspension (due to the heavier engine/box of the VR6).
5) New Radiator (bigger)
6) New fuel pump (bigger)
7) New Water pump (bigger)
8) New ECU.
In short mate, if I was you, i'd go down the route of finding a 2.8L thats been stuffed, with a decent front end.
Wip out the engine& g'box, suspension, basically everything under the front bonnet (INCLUDING the ECU!)
Then you might just do it!
Otherwise you'll be fecking around for ages!
Good luck dude, and post some pics when you've done!
  • 1 month later...
  • 1 month later...
