BFC Posted August 16, 2005 Report Share Posted August 16, 2005 Hi Just purchased a 02 Passat and are having problems with the central locking. On the first press of the button the drivers door opens as expected (like my Audi Allroad) but when I press the button a second time to open the other doors nothing happens. The door knobs move a little but don't rise up and open the other doors or indeed the boot. I have to open the car with the first press and release the other doors by pressing the unlock button on the inside of the door. I have tried holding button for 1 second then opening / closing the door to reprogramme as per the manual to no effect. All opens normally if I use the key and turn twice in the lock. Any help appreciated!!?? Link to comment Share on other sites More sharing options...
felixthecat1 Posted August 16, 2005 Report Share Posted August 16, 2005 I assume it locks all the doors okay, does it? First place to try is always the fuse box but if the plungers move slightly it points to a mechanical problem. Unfortunately this happened to me twice and I had to get the faulty lock replaced by the stealer. You may have more luck though Link to comment Share on other sites More sharing options...
BFC Posted August 16, 2005 Author Report Share Posted August 16, 2005 Hi yes it locks OK would assume as all the plunges move that it would be unlikely that all 3 incl boot lock mechanisms are faulty. Where would I find the fuse? many thanks Link to comment Share on other sites More sharing options...
Mook Posted August 16, 2005 Report Share Posted August 16, 2005 One fuse works all of the central locking. It sounds like it could be a dodgy solenoid or even a broken wire? If you've just bought it from a main dealer, take it back and get them to fix it under warranty. If it's not from a main dealer, but another dealer, take it back and ask them to fix it. Link to comment Share on other sites More sharing options...
felixthecat1 Posted August 16, 2005 Report Share Posted August 16, 2005 [ QUOTE ] One fuse works all of the central locking. It sounds like it could be a dodgy solenoid or even a broken wire? If you've just bought it from a main dealer, take it back and get them to fix it under warranty. If it's not from a main dealer, but another dealer, take it back and ask them to fix it. [/ QUOTE ] Can't really argue with that. Take a Rocket with you. [ QUOTE ] Where would I find the fuse? [/ QUOTE ] To answer the question it's behind a panel on the drivers side. Open the drivers door and it's on the side of the dash where the door comes to rest, just to the right of the headlight switches. Link to comment Share on other sites More sharing options...
Wobby Posted August 16, 2005 Report Share Posted August 16, 2005 [ QUOTE ] . You may have more luck though [/ QUOTE ] Link to comment Share on other sites More sharing options...
felixthecat1 Posted August 16, 2005 Report Share Posted August 16, 2005 [ QUOTE ] [ QUOTE ] . You may have more luck though [/ QUOTE ] [/ QUOTE ] Wot? Link to comment Share on other sites More sharing options...
Wobby Posted August 16, 2005 Report Share Posted August 16, 2005 nothing. I am saying nothing! Link to comment Share on other sites More sharing options...
mulkbear Posted August 16, 2005 Report Share Posted August 16, 2005 I say this every time. 1. is the n/s/f carpets wet or damp ? 2. Has the car a water ingress in the past ? (if the fuse had blown the windows will not work) Link to comment Share on other sites More sharing options...
BFC Posted August 17, 2005 Author Report Share Posted August 17, 2005 NOT BOUGHT FROM A DEALER, BOUGHT PRIVATE. Where can I find the sloenoid that may be broken? Should I get a auto electrician to sort and fix or does it have to be VW!!?? Link to comment Share on other sites More sharing options...
Mook Posted August 17, 2005 Report Share Posted August 17, 2005 [ QUOTE ] NOT BOUGHT FROM A DEALER, BOUGHT PRIVATE. [/ QUOTE ] OK buddy, don't shout! An auto electrician should be able to fix it for you, although if it needs new parts, they may need to come from VW. Best of luck Link to comment Share on other sites More sharing options...
Wobby Posted August 17, 2005 Report Share Posted August 17, 2005 I think hes just using the Capitals to highlights the important part, this isnt MSN or a chat room. Just ignore him BFC.... you shout if you want to Link to comment Share on other sites More sharing options...
Mook Posted August 17, 2005 Report Share Posted August 17, 2005 WHAT WAS THAT WOBBY..?! What's MSN anyway? Link to comment Share on other sites More sharing options...
BFC Posted August 17, 2005 Author Report Share Posted August 17, 2005 NOT SHOUTING AT ALL!! just happened to have the caps lock on and upon realising couldn't be bothered to go back and retype. Link to comment Share on other sites More sharing options...
m411as Posted October 10, 2010 Report Share Posted October 10, 2010 i have the same problem with my passat. my carpets have been wet and i have replaced the box under the passenger seat that controls the electrics. my key fob doesn't work at all. does it just need re programmed??? also the boot doesnt open i have to get out and open it with the key. its a pain in my arse!!! Link to comment Share on other sites More sharing options...
TIDYDUBS Posted October 13, 2010 Report Share Posted October 13, 2010 Usually a good old terminal 30 reset disconnecting the battery positive and negative for approx 5 mins should do the job. Thats if locks unlock but wont fire the rest up......the other thing code the remote as easily done by yourself............ Link to comment Share on other sites More sharing options...
