mb Posted September 17, 2005 Report Share Posted September 17, 2005 Hi the transformer on my (house) alarm has packed up - the input to the PCB is labelled 21VAC but when I look at Maplins they only seem to have 12V or 25V. Does anyone know where I can buy a 21VAC transformer or if it would be OK to give the alarm panels 25VAC ? Thanks Martin Link to comment Share on other sites More sharing options...
hotdog Posted September 19, 2005 Report Share Posted September 19, 2005 What make is the alarm system? 21Vac is very unusual! Normally they are 11.4 to 12.8v. Link to comment Share on other sites More sharing options...
mb Posted September 20, 2005 Author Report Share Posted September 20, 2005 Hi - it is a Scantronic 9448, I have managed to find a panel on ebay so hopefully this will no longer be a problem. The panel has an input that states 21VAC on it. The internal fuse kept blowing (immediately) & when I tested the transformer it produced about 2 V before promptly exploding ! Maplins have 12 V & 25 V AC Transformers so if the panel doesn't come off will probably try one of these - would you risk 25V or go for 12 and see if that works first ? Tjanks Martin Link to comment Share on other sites More sharing options...
hotdog Posted September 20, 2005 Report Share Posted September 20, 2005 The 25v would be preferable as if the voltage is lower the panel will draw excessive current. Let me know how the Ebay thing goes. Meantime I'll ring a few contacts see if they can't dig one out Link to comment Share on other sites More sharing options...
mb Posted September 22, 2005 Author Report Share Posted September 22, 2005 Thanks for your help - the e-bay one sounds like it will come through otherwise I will try the 25V version from Maplins. Thansk for teh advice Cheers Martin Link to comment Share on other sites More sharing options...
