golf brake update to rs4/rs6 possible?
Golfmaster
My car will have a 17" wheel. do you think to put an rs4 or rs6 i will only need to put a spacers?
I'd tink it will require a bit more than just spacers! The car you have and the cars the desired brakes come from have different hub station and brake set-ups; ie, hangers, calipers, disks, etc and so it you'll need some sort of conversion kit to allow the calipers and disks to be fitted.
For one the disks on the RS4 and RS6 will have a 5x112 bolt pattern where as you have a 5x110 bolt pattern, so straight off you'll need adapters to fit the disks to your hubs.
If you want bigger brakes, better off looking at the 'Big' brake kits on offer for MKIV golfs as these have been designed to bolt right onto you car.
