noco68 Posted September 19, 2005 Report Share Posted September 19, 2005 I am trying to fit new front indicator units (don't ask why, long story...) into my '96 S6. Have the units - per the owners manual I've slid them into their respective guides, etc. but I can't get them to 'click' back into their seating - it almost appears as though the new units aren't long enough...! (The units are original Audi from the local dealer.) Anyone out there with a knacky way of making these things fit? I'm close to wandering off into the dealer and letting him charge me an hour for this Link to comment Share on other sites More sharing options...
cruiser647 Posted September 19, 2005 Report Share Posted September 19, 2005 Hi! I think these units are all about the same for all early(ish) Audis. I had to change the unit on my A8. Came off OK, but took 20 mins to fit it back in! You really have to push the unit hard in and then fiddle with the 'locking bit' behind - where you cannot see! IIRC, you have to fold the locking bit over - then it clicks in. Put the old one back and feel how it is. It is just that the new one is stiff. I also took the headlamp backing plate off for easier/more access. Good luck! Link to comment Share on other sites More sharing options...
noco68 Posted September 19, 2005 Author Report Share Posted September 19, 2005 Thanks, cruiser647. Good to know I'm not being particularly thick (and you understood what I was on about...)! But it sounds like a bit of brute force and ignorance is required, yes? When you say to fold back the locking bit - is this the locking bit on the unit itself or the corresponding (stationary) bit backing onto the headlamp? Or both, even? One other thing, can removing the headlamp backing plate affect the beam alignment? Have the Irish equivalent to the MOT coming up and don't want to have headlamp beams messing me up if I can help it... Thanks again, Edna'... Link to comment Share on other sites More sharing options...
cruiser647 Posted September 19, 2005 Report Share Posted September 19, 2005 Removing the headlamp backing plate won't change the alignment (need funny screwdriver thingys for that). IIRC.........with the indicator out, you should be able to see where the white plastic bits locate onto the headlamp unit.......then slide the indicator in and push the locator clips down onto it.......(this is all from a poor memory from January!!) Link to comment Share on other sites More sharing options...
