wrighthere Posted September 20, 2005 Report Share Posted September 20, 2005 I have a Passat TDI S-Reg and the other day I managed to snap off the electric wing mirror knob on the drivers side. Does anyone have any clue where I can get another one? I guess I need to buy the unit it goes into as well? Link to comment Share on other sites More sharing options...
Mook Posted September 20, 2005 Report Share Posted September 20, 2005 It is one unit and, unless you can get a replacement from a breakers yard, it is a main dealer part only. You will need to remove the door panel to replace it - a fairly straight forward job which should take about 15 minutes or so, or ask your friendly local VW specialist. HTH Link to comment Share on other sites More sharing options...
wrighthere Posted September 20, 2005 Author Report Share Posted September 20, 2005 I guess they will change me a small fortune though!!??? Will give them a shout! Cheers Link to comment Share on other sites More sharing options...
asta Posted September 20, 2005 Report Share Posted September 20, 2005 removeing the door panel 15 mins?!!?! hehe a bit optimistic unless youve done it before try a breakers yard as golfs will probably be the same too Link to comment Share on other sites More sharing options...
Mook Posted September 20, 2005 Report Share Posted September 20, 2005 [ QUOTE ] removeing the door panel 15 mins?!!?! hehe a bit optimistic unless youve done it before try a breakers yard as golfs will probably be the same too [/ QUOTE ] Best to be optimistic then... Link to comment Share on other sites More sharing options...
mulkbear Posted September 21, 2005 Report Share Posted September 21, 2005 No need to remove the door panel, just screw a self tapper screw in to the centre of the unit and pull it out with some pliers and plug the new one in and push to new one it the hole. (trade secret ) Link to comment Share on other sites More sharing options...
wrighthere Posted September 22, 2005 Author Report Share Posted September 22, 2005 Excellent, cheers for that! Link to comment Share on other sites More sharing options...
