Key fobs not working
pugboy
Bought a 2001 Passat for the wife last weekend at auction. Unfortunately neither key fob works. frown.gif
The button lights up on both of them so I'd guess that batteries are ok?
I have tried reprogramming as per the owners manual, but that made no odds.
I get the impression that this is a common problem so fingers crossed you guys can help.
Thanks in advance.
Adam.
Adam - if the keys never work, perhaps the keys need to be sync'ed with the car? The instructions are in the manual and it is very easy to do. I think you press and hold the lock or unlock button for a second or so, then insert key into the driver's door lock then press the lock and unlock button again.
The keys will be desync'ed if pressed too many times away from the car.
Another possibility - especially if the key fob works occasionallly - is one of the Passat's many electrical frailties - solder joint cracking inside the driver's door. The fix for that is described here (I'm planning to try it on my car soon):
http://www.taligentx.com/passat/maintenance/doorlockmechanism/
  • 5 years later...
Try Removing the battery and testing the battery with volt meter sould be 3 volts
Or some key are this type
Batteries that fit the key fobs are know as:
MAPLIN - ZB74R
IEC - CR2032
ANSI - 5004LC
DURACELL - DL2032
VARTA - CR2032
ENERGIZER - 2032
KODAK - KL2032
PANASONIC - CR2032, BR2032
RAYOVAC - CR2032
OTHERS - LF-1/2V
Edited by WhyJayDee
make it easier to understand
