corindm Posted September 29, 2005 Report Share Posted September 29, 2005 I'm looking for upgrade the front speakers in a 2005 A3. Has anyone done this before? I'd appreciate the benefit of someones experience in terms of how the door panels are removed - don't want to break anything! Link to comment Share on other sites More sharing options...
John32 Posted September 29, 2005 Report Share Posted September 29, 2005 Hi Can't help with the installation as had mine done rather than DIY. Can say that 6.5" fitted no problem - just need some spacers. John Link to comment Share on other sites More sharing options...
corindm Posted September 29, 2005 Author Report Share Posted September 29, 2005 where did you have it done? Link to comment Share on other sites More sharing options...
John32 Posted September 29, 2005 Report Share Posted September 29, 2005 Hi Corin Most of the work was done by Linky , 90% happy with them - really depends on what fitter does the job Link to comment Share on other sites More sharing options...
corindm Posted September 29, 2005 Author Report Share Posted September 29, 2005 Yes thats exactly the issue, i'm looking for a good fitter really! Was hoping yours was going to be nearer to me! Link to comment Share on other sites More sharing options...
Tomk Posted September 29, 2005 Report Share Posted September 29, 2005 there wil be loads in southhampton , thing is its a 10 min job! just have a look at the door card and take it off ! no point paying someone else ! better spending the money on better speakers Link to comment Share on other sites More sharing options...
corindm Posted September 29, 2005 Author Report Share Posted September 29, 2005 Its a ten minute job for someone with a crowbar. I've not found anyone in southampton that has done an A3. Link to comment Share on other sites More sharing options...
Chillihead Posted September 30, 2005 Report Share Posted September 30, 2005 Not a hard job at all, fitted new front and rear speakers to 99 3dr last weekend. Front doors easy. remove two screws from upper trim, one from door handle, remove plastic shroud, then two more screws. Lift door card and there you go. Rear a little scarey, however easiest I found was to pull mid way down the door jam and then pray and tug. Easy to get back on, just watch the window trim, gets stuck. Link to comment Share on other sites More sharing options...
corindm Posted October 1, 2005 Author Report Share Posted October 1, 2005 Has anyone removed the front door trims of a 2003 -> A3?? Link to comment Share on other sites More sharing options...
corindm Posted October 1, 2005 Author Report Share Posted October 1, 2005 ok, managed to get the door trims off thanks to some advice from users on here Next issue is the front speakers in a 2003-> A3 need a mounting collar to distance the speaker from the door. All the adaptors I can find online are for the 1996-> A3 which isn't deep enough. Can anyone suggest where I can get an adaptor for the new A3 or even a generic one for 13cm speakers? Link to comment Share on other sites More sharing options...
corindm Posted October 2, 2005 Author Report Share Posted October 2, 2005 I lied....the front speakers are 16cm not 13! Link to comment Share on other sites More sharing options...
