golf engine swap
vikder1982
i have a few queries i need some help with i f possible.i have a 1981 vw golf gti 1.6 and i have a golf gti mk2 1.8 16v, im planning on putting the mk2 engine in the mk1 along with the dash and wiring loom as the dash and loom are atrocious in the mk1.does anyont know of any problems i may encounter or any bits i may need, im also gonna use the brakes from the mk2, but i know about the scirocco carriers needed and the brake servo.any help would be appreciated. smashfreakB.gif thanks.
Where do we start?
MK1 fuse box in on the N/S of the car and the mk2 is on the O/S, So what ever you do all the other wires in the car will have to be extended to meet the other fuse box.
The fuel line will have to be moved to the O/S of the engine bay the washer bottle move to the other side, unless your using a scirocco inlet manifold.
You need to make new top hose for the rad.
Yes you will need the scirocco carriers and outer CV joints, You need the MK2 16v brake servo and master cylinder and Peugeot or Fiat dist cap (to clear the larger servo). There also all the little bits i've missed, Good luck cause it well worth it when it done 169144-ok.gif
When we did it [it's a long time ago now crazy.gif] we used all the mk2 wiring for the front of the car (fuse box/dash/engine/lights)
the only wiring left to sort is that going to back (fuel pump /lights)
we also used new mk2 fuel lines (plastic) from the pump/tank to the front as the original lines (metal) were a bit 'old'
make a good job of the brakes....the originals will be on the limit..!
you mentioned plastic fuel lines.any chance of knowing where i can get some from, it saves me using the old lines.also is it possible to install the mk2 dash without extending the wiring, as i was thinking of relocating the fusebox to the same side as it is in the mk2.thanks again.john
The fuel lines were std VW parts for a mk2 golf gti 16v
I can't remember all the detail of the dash/wiring ?.....we did move the fuse box to the mk2 side of the car (remember cutting metal to get it in)
I am meeting up with my son on Sunday [it was his car] I will check the details and let you know.
