Ari Posted October 15, 2005 Report Share Posted October 15, 2005 I've got a scanner at home, but no printer. To be honest I very rarely need to print although it would be useful occasionally (at the moment if I need to print anything then I have to email it to work and print it). However it strikes me that the space the scanner is taking up could better be used by a scanner/printer which would probably take up the same shelf space but be way more useful. As I say, I only want to use it occasionally, so don't want to spend a fortune, so whats a good cheapy scanner/printer? Also, I've only got two USB ports on my PC. One is used by the cordless mouse, the other by my illuminated keyboard. So how can I plug my new printer in when I get it? (Everythnig seems to be USB connected these days). All advice gratefully received as ever. Link to comment Share on other sites More sharing options...
NeilB Posted October 15, 2005 Report Share Posted October 15, 2005 I've got myself a Belkin 8 port USB hub works fine and I've got one port free at the moment, you could put another 4 USB ports in by buying a PCI card and inserting it into the motherboard if you have a free slot. Manged to find this HP PSC 1315 for about £82. Seems to be an ok AIO jobbie with people saying the quality of the print out's are pretty good. The only moan people have with it is that it doesnt come with a fax. Link to comment Share on other sites More sharing options...
CarMad Posted October 15, 2005 Report Share Posted October 15, 2005 Got a 1215 that I bought my other half to use at uni. Have to say its really good for the money. Not the best at printing or scanning but it certainly does the job for 90% of situations. The models above are probably a little better. But I would certainly recommend it. Link to comment Share on other sites More sharing options...
Ari Posted October 15, 2005 Author Report Share Posted October 15, 2005 Sounds good chaps. Not bothered about a fax, so not a problem to me. Link to comment Share on other sites More sharing options...
ian_m Posted October 15, 2005 Report Share Posted October 15, 2005 Nick, Asda do a Lexxmark printer/scanner/fax for £50 Link to comment Share on other sites More sharing options...
A3TDI Posted October 15, 2005 Report Share Posted October 15, 2005 This is a good allrounder £98 from tescos MFC-410CN General Print Engine Inkjet Scanning Method CIS Dimensions (W x D x H) *1 373 x 345 x 135 mm Weight 5.5 kg Document Input Width (Scanner Glass) 216 mm Document Input Height (Scanner Glass) 297 mm Paper Tray Capacity 100 pages Output tray Paper Capacity 25 pages PC Interface USB 2.0 Full speed/ Ethernet Port External TAD Interface Yes Memory Capacity (physical: Mbytes) RAM 16 MB Operating Environment - Temperature (BestPrintQuality) 5 - 35 (20 - 33) degrees Centigrade Operating Environment - Humidity 20 - 80 % (without condensation) Recommended Paper/ Transparencies Plain Paper Brother Inkjet Paper BP60PA Matt Paper Brother Matt Inkjet Paper BP60MA Glossy Paper Brother Premium Glossy Photo BP60GLA BP60GLP Transparency 3M Transparency Film CG3410 COLOUR FAX Modem Speed 14,400 bps Transmission Speed(sec.) Approx.6 *2 Coding Method Mono: MH/ MR/ MMR, Colour: JPEG Gray Scale Mono: 64, colour: 256 Dual Access Yes (B&W only) Delayed Timer (Up to 50: B&W only) Yes Quick-Scan (Memory transmission) Approx. 5 sec/page Broadcasting (Max.) Yes /130 locations (B&W only) Page Memory Up to 400 Pages Speed Dialing 80 Group Dialing (Max.) 6 groups ECM (Error Correction Mode) Yes Remote Access Yes Fax Forwarding Yes (B&W only) COLOUR PRINTER Speed Up to 20ppm (Mono)/ Up to 15ppm (Colour) Resolution Up to 1,200 x 6,000 dpi *3 Minimum Ink Droplet Size 3 picoliters Printing Width 8.03 inches (8.25 inches *4) 204 mm (210mm*4) Disk-Based Fonts 35 TrueType COLOUR COPY Resolution Print: Max. 600 x 1,200 dpi Scan: Max. 600 x 1,200 dpi Reduction/ Enlargement 25% - 400% in 1% increments Multi Copy (Stacking) Up to 99 Multi Copy (2 in 1, 4 in 1) Yes COLOUR SCANNER Optical Resolution (dpi) 600 x 2,400 dpi Interpolated Resolution (dpi) Up to 19,200 x 19,200 dpi *5 Scan Key Yes + Scan to Image/ E-mail/ OCR/ File/ Card *8 TWAIN Compliant Yes *6 Gray Scale 256 Colour Depth (Input/ Output) 36/ 24 bit colour processing Viewer for Windows® (including ScanSoft® OmniPage® OCR) ScanSoft® PaperPort® 9.0 Viewer for Macintosh® (Including OCR) Presto!® PageManager® PC FAX Sending Yes (B&W only) Receiving Yes (Not supported for Macintosh® or network users) PHOTO CAPTURE CENTER™ Acceptable Media Card & Size *9 *10 SmartMedia® (3.3V): 4MB - 128MB CompactFlash® (Type-1 only): 4MB - 2GB Memory Stick®: 16MB - 128MB (Duo with Adopter) Memory Stick Pro™:256MB - 1GB (MagicGate: Yes if not using MG function) Secure Digital™: 16MB - 512MB (MiniSD with Adopter) xD-Picture Card™: 16 - 512MB Direct Photo Printing Yes in JPEG format Removable Disk Yes (Read/ Write) Scan to Card Yes in TIFF/ JPEG/ PDF format NETWORK Model Name NC-110h (Embedded) Network Connection Ethernet 10/100BASE-TX Auto Negotiation Share Printer Yes Share Scanner Yes Share PC-FAX Sending Yes Share PhotoCapture Yes (Browsing only) Support Protocols TCP/IP - RARP, BOOTP, DHCP, APIPA (Auto IP), NetBIOS, WINS, LPR/LPD, Port9100, SMTP/POP3, FTP, TELNET, SNMP, TFTP, mDNS, Scanner port Network Management Tool Brother BRAdmin Professional Operating System For Windows® user Windows® 98(SE)/ Me/ 2000/ XP For Macintosh® user *7 (for Printer) (for Scanner) (for PC-FAX send) (for Removable Disk Drive) Mac OS® 8.6 - 9x, Mac OS® X 10.2.4 or greater Mac OS® 9x, Mac OS® X 10.2.4 or greater Mac OS® 8.6 - 9x, Mac OS® X 10.2.4 or greater Mac OS® 9x, Mac OS® X 10.2.4 or greater Link to comment Share on other sites More sharing options...
