Unable to access some control modules
coodem
I have a 2002 Audi A 1.9Tdi and have recently upgraded my standard radio to the RNS-E. All seems to be working fine. track info is shown on the DIS.
But never the less I tried to connect to module 37 (Nav), also tried module 56 (radio) but unable to connect to either.
I am using a full/unlocked version 311.2-N, also tried the free download version 409.
I have a usb vag-com that supports Dual K lines and am able to connect to the following modules 1, 3, 8, 9, 16, 17, 45, 46
I have read that the nav unit needs the K-line connected and have checked this. Is the problem with the software version? Will buying the latest Key Com usb and using software version 5+ work. I plan to do the OEM BT install and I will need to be able to connect to this module to get to work.
Thanking you all in advance
