roohster Posted October 18, 2005 Report Share Posted October 18, 2005 Coupla questions; 1)Can anyone tell me what bulb fitting a 2000 S3 ("facelift model") uses? It's fitted with xenons, but I'd like to upgrade the main beam and fogs to a whiter light. 2) How do you get at the bulbs?! 3) Can I adjust the dipped beam? It seems to be set way too low. Thanks! Link to comment Share on other sites More sharing options...
doogal1972 Posted October 18, 2005 Report Share Posted October 18, 2005 Not sure if you can change just the bulbs or not in the other lights but xenons are self leveling so they can't be adjusted. Link to comment Share on other sites More sharing options...
roohster Posted October 18, 2005 Author Report Share Posted October 18, 2005 Not sure what you mean by "just change the bulbs".... Link to comment Share on other sites More sharing options...
doogal1972 Posted October 18, 2005 Report Share Posted October 18, 2005 I wanted to replace just a lense on one of my foglights as it was smashed, and was told you can only buy the whole light as one unit. Link to comment Share on other sites More sharing options...
roohster Posted October 18, 2005 Author Report Share Posted October 18, 2005 yeah, but you wouldn't have to replace the whole unit, I'm just talking about the bulbs.... Link to comment Share on other sites More sharing options...
Hopsta Posted October 18, 2005 Report Share Posted October 18, 2005 Handy site http://www.1stautobulbs.com/ Link to comment Share on other sites More sharing options...
Viraje Posted October 18, 2005 Report Share Posted October 18, 2005 [ QUOTE ] Not sure if you can change just the bulbs or not in the other lights but xenons are self leveling so they can't be adjusted. [/ QUOTE ] Unless you adjust them with the manual adjuster, or vag-com. It's a common problem, Search is your friend.... Link to comment Share on other sites More sharing options...
roohster Posted October 19, 2005 Author Report Share Posted October 19, 2005 [ QUOTE ] Unless you adjust them with the manual adjuster, or vag-com. It's a common problem, Search is your friend.... [/ QUOTE ] I've tried searching and can't find anything..where is the manual adjuster? Ta. Link to comment Share on other sites More sharing options...
roohster Posted October 19, 2005 Author Report Share Posted October 19, 2005 Anyone?............... Link to comment Share on other sites More sharing options...
khufu Posted October 19, 2005 Report Share Posted October 19, 2005 I swapped my sidelight bulbs for white LEDs. They look a lot better with the Xenons but arent stricly legal. Have got better H7 headlight bulbs in but cant rememeber the make, probably phillips. Some S3 owners suggest disconnecting the power to the adjusters and set them yourself. The manual ajuster in on the top, its white and shaped like a cog (i have pre-facelift lights though) Link to comment Share on other sites More sharing options...
roohster Posted October 20, 2005 Author Report Share Posted October 20, 2005 Thanks Khufu, I want to change the sidelight, foglights and main beams.... so is that H7 for main beams? Ive found the white coggy thing... will that adjust them without disconnecting? Link to comment Share on other sites More sharing options...
roohster Posted October 21, 2005 Author Report Share Posted October 21, 2005 Ok, now Im officially confused... according to the link posted by Hopsta, the main beam is an H4 fitting. I thought H4 was a dip/main bulb (ie does both)? Link to comment Share on other sites More sharing options...
Viraje Posted October 23, 2005 Report Share Posted October 23, 2005 Links here, here, here, or even here. Link to comment Share on other sites More sharing options...
roohster Posted October 23, 2005 Author Report Share Posted October 23, 2005 Ok, I think I'm sorted... the xenons can be adjusted via the white nylon screws above the units... and apparently main beam and foglights are both H7s. PIAA here I come! Link to comment Share on other sites More sharing options...
