Help please - what products to choose
Velour
Hi all,
Just bought a 330d in special order techno violet. I really like this colour so looking to spend some time on the cleaning / polishing to make it look its best.
No idea which products would work best for a deep metallic colour though?
Seems that Zaino Z2 or Colinite 845 would do good things, not sure what to put them on top of though.
Any advice greatly appreciated.
Keith
Sequence of Product Application:
Recommended products / sequence to obtain the highest level of optical light refraction and reflectivity
1.Car wash concentrate- Menzerna Auto Shampoo
2.Detailer’s clay- Clay Magic™ ‘Blue
Machine polish abrasion choice is dependant upon condition of paint surface
3.Machine polish 1- Menzerna Power Gloss Compound
4.Machine polish 2- Menzerna Intensive Polish - Menzerna PO106FF (for CeramiClear)
5.Machine polish 3- Menzerna Final Polish II 2- Menzerna P085RD (for CeramiClear )
6.Glaze- Menzerna Finishing Touch Glaze2
7.Chemical cleaner- Klasse All-In-One or Z-PC Fusion Dual Action Paint Cleaner Swirl Remover
8.(LSP) Polymer sealant- Z2PRO™ Show Car Polish + ZFX™ Flash Cure Accelerator Additive, spray applicator and vehicle surface with Z-6™ Ultra Clean Gloss Enhancer Spray between layers
9. Booster spray- spray surface with Z-8 Grand Finale™ Spray Seal
Or Omit the Z-8 Grand Finale™ Spray Seal and apply a Carnauba wax as a last step product (LSP)
8a. (LSP) Carnauba wax- Pinnacle Souverän Paste Carnauba
9a. Quick Detailer Pinnacle Crystal Mist
Notes:
1.As long as you have an understanding of what each step does you can alter the sequence or omit steps in the sequence to suit paints condition / needs
2.A polish that contains oils should be cleaned with a 1:1 solution of Isopropyl alcohol / distilled water before the application of a polymer (oils will not effect the setting-up of a Carnauba wax)
3.You cannot apply a polymer over a Glaze or a Carnauba wax due to bonding incompatibility
4.Carnauba wax will bond to a cross-linked polymer; conversely if a polymer is applied on top of Carnauba wax the polymer cross-linking / bonding may be compromised.
5.Although I would not state categorically that a product that is formulated with oils will abort the cross-linking or bonding process of a polymer just that the process may not be as complete, and its strength and durability may be adversely affected
If there are steps or products processes that you don't understand pls send an e-mail or post ??? to forum.
JonM
