IT people - i need help!
simonb
Currently working on a project, whereby i have to differentiate between 2 projects that my company is going to tender for.
I need to present my Commercial Director with a decision tree.
What software would be best for this?
I need to draw lines, circles, boxes and add text etc. IT isn't my forte - i've got basic programmes.
Word would be ok apart from when you add other bits it always seems to go t1ts up. Paint is ok too but difficult to edit later.
I was thinking Excel but i need to draw horizontal, diagonal and vertical lines which is possible but i would prefer the diagonal likes to go to the middles of the node boxes rather than to the corners.
Any suggestions chaps??
Also - PDF files.
How do i create one? I have Adobe Acrobat but only ever used it for viewing. Is it as simple as 'Save As', the change file type from .doc, or .xls etc to .pdf??
Hi,
For diagrams like that i use M$ Visio which is pretty good although not cheap.
As for creating PDF's i use a product called Primo PDF which you can get from www.primopdf.com it installs as a printer so just go into any app click on print and select the Primo PDF printer. It will then promt you for a location to save the file.
Jon.
Not sure on the PDF's but definitely another vote for Visio to map things. I work as a project manager and use Visio a hell of a lot - very easy to use and produces really good results meaning you don't spend a week trying to explain the process flow to a client 169144-ok.gif
Most apps like Word, Project, Visio, etc can 'print' to PDF so long as you have the Acorbat installed and 'print to PDF' function.
so, you can diagram you decision tree and then 'print' to PDF.
Easy peasy!
Jon.
