air con on climate control
eatmysmoke
I have a mk4 golf gt tdi. It has the climatronic climate control. does this have air con,and is it turned on when you set the temperature to low. just it never seems to be that cold in hot days. and when the sun sun shines on the display of the climatronic i can see an icon for air con but i've never had the icon turned on.
Any help would be appreciated
Thanks
Rick, its 'air con' all the time, unless you see the "ECON" icon lit 169144-ok.gif
Climatronic is the advanced version of plain air con (with the rotary dials). You set the temperature and the system maintains it smile.gif
If its not getting cold then there could be a fault or you might need to have your air con system regassed...
