Brakes fitting
pambs
I'm thinking of buing an a4 cabrio 1.8T and i wanted to know what brakes would fit in. I have an endless big brake kit that i used to had on my 300zx it has 6 pistons calipers and 322x28mm discs and racing pads and i would like to know if they'll fit the A4 or should i sell them cofiguration on the z is 5x114.3
Pambs - the A4 pcd is 5x112 - so your 300zx discs won't fit. It may be possible to machine an adapter for the calipers and use different discs.
The B6 A4 (and I assume the cab too) will take B5 S4 or B6 S4 front calipers and discs as a cheaper upgrade than going aftermarket (assuming you can get hold of a secondhand set). Plenty of guys on audiworld.com have done this mod.
