Tomk Posted October 25, 2005 Report Share Posted October 25, 2005 right have a prob on my net work , 2 pcs both installed with xp , i can browes computer A from computer b ok eg start > run > computername c$ etc but if i try and do the same from computer B i get access denied even though permissions are set the same ! dont know were to start its really annoything ! Link to comment Share on other sites More sharing options...
Frodo Posted October 25, 2005 Report Share Posted October 25, 2005 Technically you are not browsing, you are making a connection via a unc path. Anything in the security event log of event viewer? Sounds as though you are making a connection because otherwise you wouldn't get accessed denied. However, when it says access denied does it then provide you with a secondary logon box? If so try local\administrator as the username and the password for the remote machine if they are not in a domain. Link to comment Share on other sites More sharing options...
Tomk Posted October 25, 2005 Author Report Share Posted October 25, 2005 it comes up blanked out i cant add a username or pw ! Link to comment Share on other sites More sharing options...
mb Posted October 25, 2005 Report Share Posted October 25, 2005 Are you running F-Secure - the firewall blocked n/w browsing on my LAN - unless you "trust" the n/w adapter ? Link to comment Share on other sites More sharing options...
Tomk Posted October 25, 2005 Author Report Share Posted October 25, 2005 im not running anything Link to comment Share on other sites More sharing options...
Hopsta Posted October 25, 2005 Report Share Posted October 25, 2005 switch off the XP firewall then try it. Link to comment Share on other sites More sharing options...
aal234 Posted October 25, 2005 Report Share Posted October 25, 2005 try creating an identical login on both machines then try browsing. I had this problem between an xp home and win 2000 box. Link to comment Share on other sites More sharing options...
Frodo Posted October 25, 2005 Report Share Posted October 25, 2005 XP Home is crap in my opinion. Many of the things that work in professional, 2000, NT just don't work on Home. Link to comment Share on other sites More sharing options...
aal234 Posted October 25, 2005 Report Share Posted October 25, 2005 actually i'm not sure if tom is running home, either way I agree it gets on my nerves as it takes the noddyness (is that a word) of XP to extremes! Also have you tried giving permissions to the username you are using on the root of c? Link to comment Share on other sites More sharing options...
jpringle819 Posted October 28, 2005 Report Share Posted October 28, 2005 What you need to do is open the local security policy and go to computer configuration\windows settings\security settings\security options and look for the policy called Network Access: sharing and security model for local accounts. This should be set to classic. If you are trying to access the machine with an account with a blank you will need to find the policy accounts: limit local account use of blank passwords to console logon only, and set this to disabled. The final thing you will need to do is configure a shared folder and set the sharing and ntfs permissions on this. James Link to comment Share on other sites More sharing options...
