new door lock - does anything need reprogramming
Shorty
the drivers door lock has stopped working, so i took the lock out and tested it.the key turns but the back of the lock doesn't so i assume a new lock is the answer.
the question is does anything need to be reprogrammed.(as the new lock will need a new key) ?
did think about swapping locks over but passenger wont fit drivers side
it is a re-programming jobie, but if u know someone who has a vag-com then maybe they could do it for u?
so as it has an immobiliser, the key will have a small chip/similar thing, so the new key will need to be programmed, and then you will have to replace the Ignition barrel so that the new key fits unless you fancy carrying 2 keys? ...personally not!
if you cant get in touch with someone local who has a vag com then i suggest sourcing a local independant...it may be cheaper.
Also dont quote me on this but...a mate of mine had to replace the locks, barrels on his Honda and he had to tell his insurence company. (it made no difference to his preimum) as i sed dont quote me on this bit...but would suggest gettin clarification on that part.
i emailed my local vw garage and the reply was the barrel does not come with keys because it is made to the keys which you already have. .I take it that they will need the keys in advance to do this, if not how do they match them to the lock confused.gif .cheers
There should be a plastic tag which came with the original keys (has like a scratch card silver strip on it) which could have the relevant data on it. Or they may be able to order a barrel from your VIN Number. The days of someone taking a barrel apart and rebuilding it to suit a specific key are long gone, I should think.
Thanks to everyone for your help.This is the reply to my email i received this morning from the VW garage.
I will need full reg of car and full chassis number and full payment in advance because it is made to your car and wont fit any other. i dont need any of the keys the barrel is made to the car because it is laser cut
