Windows 2003 Server SMTP issues
Sparky
I've got a new Windows 2003 server setup with the Windows SMTP service that sends out emails. It sort of works, but not fully.
The SMTP Server has a domain called "TestServer" for example.
Emails to any address get sent quickly and without an errors. However, if I try sending an email to "[email protected]" - nothing appears to happen.
No errors. Just no mail.
I've been told that I might have setup this server as a PDC and that it's trying to handle the emails locally, but I know I've not set it as a PDC. Also, he's told me to turn off Microsoft networking crazy.gif
Can anyone help? I'm losing hair and sleep over this one!
Hi,
Yes, IIS SMTP component.
It's a server at a hosting centre so sending out emails from itself.
We have a hosted POP3 account (provided by the hosting centre), so "local" emails, should be going there to be collected by staff using Outlook - pointed at this POP box.
Instead, these emails just vanish. Or at least the log files indicate it's sending OK.
Could you run 'nslookup' from a command prompt
then 'set type=mx'
and type the problem domain.
This should then return where you server thinks mail should be delivered, these problem often seem to be DNS related.
Also could you send me an email from the server? if so I can check the logs at my end, might help? will PM address if possible.
John
I think I've solved it.
In the IIS panel, where you create new Domains, I entered our website name, without either the www or the .com as I thought it was a Friendly Name, like each website you create in IIS.
It turns out it's not. You need the proper website name in there. smashfreakB.gif
Thanks for your prompt assistance though John. Good to know there are always people on here willing to help.
I'll just go crawl under a small rock now....
