RNS-E and 4GB SD Cards
I have had limited success with a 2GB card, I limited the number of directories + files to around 400. The card usually loads up OK, but often freezes when playing a song (either the time display stops updating, or it continues but with no sound).
As a test I deleted all other albums except for the one containing the one that froze and it still hung. I the cleared the card and reloaded on the 2GB (and also a 128MB) card and miraculously both worked fine.
The one wrinkle is that I am using an Apple Mac, and need to delete all sorts of hidden files from the card before using it (._DS_STORE and the resource forks for all MP3 files).
I will try doing it via Windows next.
Any ideas?
Any ideas?
Sounds like you've got an MLC (low speed) card. There's been several discussions about this on the Navplus forum. To summarise, MLC (low speed) cards need all the data written to them in one go, and even then may experienece freezing after a period of use. SLC (high speed, and higher cost) cards don't suffer from this problem.
I've got an RNS-E and ONLY use SLC (high speed) cards, and I've never seen the problem.
Oh great - more variables! How do I tell whether the cards I have are MLC or SLC?
I use 1GB cards at the moment, and I'm definitely going to upgrade to 4GB cards when I can "persuade" the holder of the purse strings to let me.
I rip my MP3s at 320kbps so each track is about 10MB, so with an average album being 13 tracks that means I need 130MB and 14 "files" per album. So if the limit was the 512 files then I would get 36 albums per 4GB card, but that would need over 4.5GB - so I would still be capacity limited.
I guess the answer to the question "what size SD card should I buy" has two parts - what bit rate do you rip at, and what can you afford?
Mine are ripped at 192k looking around the 4gb are about £220 and the 2gb £130. I assume you have 2 x 1GB cards and use both slots, how does the system distinguish between slots or does it make what's on both SD cards available to choose from in one hit? I've got a little time to decide before the car arrives.
It lists card 1 and card 2 separately, and you select either card 1 or card 2 to play.
I had a bit of a disaster yesterday - I dropped one of the cards when I was putting them back in after changing the contents on my PC. It fell behind the display and there was no way I could get it out. So I had to get my radio removal tools and take the RNS-E out, disconnect it (with the display open) and turn it upside down - the card dropped out! Sighs of relief!!!
