zchybrid Posted October 28, 2005 Report Share Posted October 28, 2005 Hi all, just wondering if anyone can give me the answer about my stereo.... I have a 2000 estate TDi SE with a "gamma" head unit which is cd compatable. someone said the car will have the wiring in the boot for cd changer, where exactly do i look?? and how many pins is the connector likely to have?? Cheers all... Link to comment Share on other sites More sharing options...
karlosthejackal Posted October 28, 2005 Report Share Posted October 28, 2005 Hi, I don't think the lead is fitted on all models, at least it wasn't on my 1998 1.8 se passat, but from reading other posts on this site, it was fitted in the factory as standard on some models, depending on year of manufacture. I seem to remember WOBBY mentioning it in a previous post, perhaps he will be able to throw some light on the subject. Link to comment Share on other sites More sharing options...
asta Posted October 28, 2005 Report Share Posted October 28, 2005 the cd changer goes in the left hand cubby hole in the boot. on mine it has a first aid symbol on it. you take off the panel and it should be sitting in there. you will need to take off the trim to see if the cables are there. there are differences because on mine there are no holes for the cables to come through. Link to comment Share on other sites More sharing options...
pugboy Posted October 28, 2005 Report Share Posted October 28, 2005 Doubt it has mate. If the car isn't equiped with the cage in the boot then I dont see why a wire would be in there. My workmate has a 00 V plate TDI and that doesn't have the wire to the boot. Link to comment Share on other sites More sharing options...
zchybrid Posted October 28, 2005 Author Report Share Posted October 28, 2005 Yeah, had a look and couldn't see any spare wires/connectors. Might see if i can stick one of the single entry "6 disc" players in the glove box, at least it'll only be a short wire from the head unit that way... Link to comment Share on other sites More sharing options...
Wobby Posted November 2, 2005 Report Share Posted November 2, 2005 A bit delayed here!! Been on holiday. It wasn't fitted on my 2001 Passat. I bought the lead with the changer. You have to remove quiet a bit of trim to run the lead properly. It took me about 3 hours to run the cable, mount a new cradle for the changer and get it up and running and put all the trim back together. If you do fit it yourself, some of the trim parts are easily breakable and its easy to miss the odd fixing. Take your time and if all the fixings are off most parts lift off easily without force Link to comment Share on other sites More sharing options...
zchybrid Posted November 3, 2005 Author Report Share Posted November 3, 2005 Thanks Wobby, i should be ok removing trims and stuff, i used to work as a stripper/fitter in a bodyshop so have all the relevent "trim tools" etc.. ebay search coming up..... Link to comment Share on other sites More sharing options...
