Symphony II - GALA settings
I have GALA enabled, so the volume should increase with speed, but it doesn't. Or at least, not by much.
I have it set to 5, which I assume is the highest setting. The manual simply says to set it to the volume differential you require.
Anyone else have GALA and how much does it increase the volume by?
My mates A3 has BOSE and although it's a different system (ie no GALA), the increase in volume is quite noticeable.
