bigger wheels... higher car
Hudster
A larger diameter wheel will generally also be wider so the tyres will be wider too, giving more mechanical grip.
The centre of gravity will be raised however, increasing bodyroll.
Since you are saying the car will be raised and there will be a greater rolling radius then the gearing will also be 'longer', so the car could take longer to reach 60 (or less time if for example before 2nd gear was 59mph at the limiter and the increased radius negates the need for another gear change), and the speedo will not be accurate.
Usually to accomodate larger wheels, you fit tyres with a sidewall lower profile so that the rolling diameter is as near as possible to the stock size, otherwise the speedo is wrong.
So, with 16" wheels and say 185/60 rubber, you'd go for something like 19" wheels with 185/40 or 225/35 rubber to get near to the same rolling diameter.
See http://www.miata.net/garage/tirecalc.html for a handy online size comparison tool.
http://www.tyresave.co.uk/tyresize.html
Is easier... You can keep the outer dimensions of the tyre virtually identical with the correct offset, maybe a little rolling of the arches.
Your ride will become a lot more crashy, as tyres do all the fine damping and suspension and a lower sidewall will remove most of that...
That's why I'm only putting 16"s on my car, compromise between handling, ride and good looks. - I could put 19"s on if I REALLY wanted!
Interestingly, BMW's Gruppe N E30 M3 racers ran on 18"s... But their suspension was rock solid with slicks and a largely smooth road surface!
I found when going from 15"s to 18"s on standard suspension, that my cars handling improved massively. She corners well, and can keep the power down better, before grip is lost.
If your only interested in twisties, and not looks, then uprated suspension is a better choice, because you get lots less body roll, and thus the car has less weight transfer issues.
As mentioned above, if you keep your car a long time, it will eat bushes, CV Boots/joints, front suspension components, if you change wheels/suspension.
WHY ON EARTH do you want a bigger rolling radius?
1) Raise your centre of gravity, messes with your handling.
2) Increase circumference of rolling stock, puts your speedo out.
3) "Juicy Bad Boy" alloys implies you only want them for the adoring looks of your peers... So why are you worried about going faster and giving people less chance to see them?
4) To maintain the same overall diameter jumping THREE inches in diameter you will need super-low profile tyres which will mean crashier handling, increased road noise, more stress on dampers and a large hike in tyre prices when they need replacing.
5) If you're concerned about handling, get some lightweight magnesium alloy Compomotive rims, maybe in conjunction with a rim increase of an inch or so.
6) If you're so ill-informed as to think that your car will drive better, you won't want to know about the ramifications for your dampers, wheel bearings and braking system.
Really sorry dude, just had to rant at someone. - I'm fine now. 169144-ok.gif
Good luck with your new rims, just make sure you've covered all angles first.
hmm forgot about the speedo... is there any solution to this apart from getting a close match to the origial diameter (inc tyres)... are speedos adjustable?
The only real option is to match the overall rolling radius of current wheels/tyres with the enw ones.
