I removed my head unit last week, just to take a look at the back & the connections prior to my i-pod install (which I've still not got round to doing smashfreakB.gif).
Ever since, MW has loads of interferance, if I brake - noise, indicate - noise - and the general signal sounds cack. I've removed the unit again to ensure all is still connected ok (which it appears to be), so does anyone know whats gone wrong??
Cheers
Al.
Update.
OK, pulled the HU out, checked the aeriel & pushed it in a liitle more securely whilst the radio was on. Seemed much better.
Slide the HU back into the slot. Then off it goes. MW vanished, just noise.
Grrrrrrreat.
If the connector is still tight, then it could be a grounding problem. We're talking low level high frequency signals here so it not just about DC grounding.
Have any of the springy metal "tabs" that press against the frame that the radio slides into got bent back or broken? That could cause the problem you're seeing.
Alternatively it could be that there's a break in the aerial cable - so when it's under tension with the HU out it's OK but when you bend it and put it under compression with the HU in the aerial connection gets lost. Try wiggling the cable with the HU out.
Sorry they're two very different suggestions - but problems with RF are like that!
