timcoupe Posted November 6, 2005 Report Share Posted November 6, 2005 Hi All, I've installed a Dietz TV module into my B6 a4 with RNS-D. I know that to enable TV in motion, I need to put a switch onto the 'Gala' wire, however, the Gala wire is split into 2 connections at the Headunit. 1 - Pin #1 on Connector III ( 8 pin ) 2 - Pin #5 on Connector V ( 25 pin ) Do I need to 'cut' the gala wire before the split or do I need to leave one of the connections 'always on' and switch the other? Thanks in advance. Link to comment Share on other sites More sharing options...
peteA3TDI Posted November 6, 2005 Report Share Posted November 6, 2005 pin 1 on the 8 pin connector (blue and white) and if you have a mf steering wheel just cut the wire Link to comment Share on other sites More sharing options...
timcoupe Posted November 6, 2005 Author Report Share Posted November 6, 2005 No MF steering wheel.. So, will keeping the connection to pin #5 on the 25 pin plug keep the 'accuracy' of the navigation unit? I have read that cutting the Gala wire will cause innacuracies? Thanks. Link to comment Share on other sites More sharing options...
mb Posted November 7, 2005 Report Share Posted November 7, 2005 Can you not just wire in a switch - so you can break the gala wire when you want to watch the TV (rely on GPS for the nav so it updates slower) but can have teh gala feed for optimum navigation when not watching TV ? Link to comment Share on other sites More sharing options...
peteA3TDI Posted November 7, 2005 Report Share Posted November 7, 2005 cut the wire and see what happens, it works fine on my A4 with MF steering wheel as long as you keep the connection on pin 5 on the 25 pin plug, if the navi is slow to update fit a switch Link to comment Share on other sites More sharing options...
timcoupe Posted November 7, 2005 Author Report Share Posted November 7, 2005 My original intention is to fit a switch, however, I know from research that you can experience slow updates on the Nav. I just wondered if you wire the switch up so that it cuts both connections or just one. Link to comment Share on other sites More sharing options...
peteA3TDI Posted November 8, 2005 Report Share Posted November 8, 2005 i think i should have gone to skool then maybe my spelling whould be better and my posts clearer anyway fit the switch to pin 1 on the 8 pin connector only not on both feeds, pin 5 is the navi feed cutting this will slow the updates Link to comment Share on other sites More sharing options...
timcoupe Posted November 9, 2005 Author Report Share Posted November 9, 2005 Thanks for the info Link to comment Share on other sites More sharing options...
