Sparky Posted November 7, 2005 Report Share Posted November 7, 2005 When I leave the house in the morning, I often put my window down to clear any rain-water on the side windows, and when reversing, I really can smell the car. It appears to really chuck some crap out, and sometimes I can see white smoke. It's the 1.9 TDi (130) engine and I've had to put 2 litres of oil in 16,000 miles into it. This never did this when new, and it's due a service in 100 miles. Could it just be waiting for the service, or is this something I need to get checked? It's certainly more than I'm used to seeing. Any advice? Link to comment Share on other sites More sharing options...
UBM Posted November 7, 2005 Report Share Posted November 7, 2005 It could be some water vapour if it is white which has collected in the exhaust pipe? I must admit, when I start mine, I can smell that lovely diesel aroma, but don't notice excessive smoke. Hoever, the last few days I have set off and can see the exhust gases rising vertically from the zorsts in the rear view mirror. I think it might just be the level of water vapour and temperature of the atmosphere. Link to comment Share on other sites More sharing options...
Sparky Posted November 7, 2005 Author Report Share Posted November 7, 2005 It is getting colder, and I am noticing it more, but the smell is usually one I link to oil being burnt off and I don't remember it doing that before. Seems a new thing. Link to comment Share on other sites More sharing options...
lmmlmmam Posted November 7, 2005 Report Share Posted November 7, 2005 Burning Oil gives blue smoke not white. If it is white smoke and not water vapour, that could indicate incomplete combustion resulting from a glow plug problem. Worth getting the dealer to look at it. Link to comment Share on other sites More sharing options...
Sparky Posted November 7, 2005 Author Report Share Posted November 7, 2005 Well I wasn't going to mention it was also blue - as the last time I did that, a techy told me I was speaking But it does both - not at the same time though! It wants a service in 100 miles (which means tomorrow then!), so I'll mention that. Is there any other signs that would indicate a glow plug problem? Link to comment Share on other sites More sharing options...
lmmlmmam Posted November 7, 2005 Report Share Posted November 7, 2005 Comparitively (better say that to stop Chav pointing out that rough is standar), rough running for the first few seconds. Your oil consumption doesn't sound that bad (c.f what some on here have suffered). Link to comment Share on other sites More sharing options...
Sparky Posted November 7, 2005 Author Report Share Posted November 7, 2005 Hmmm, well it sounds rougher (doesn't feel it though), and within seconds has dulled to a much smoother diesel rumble than when first ignition is on. I just know that unless I do some digging, Audi will dismiss it! Link to comment Share on other sites More sharing options...
bradw Posted November 7, 2005 Report Share Posted November 7, 2005 white smoke can also imply a poorly turbo. Link to comment Share on other sites More sharing options...
Durrsaku Posted November 7, 2005 Report Share Posted November 7, 2005 2 l of oil in 16k miles seems a bit much. Its been a year and 10k miles later i havent had to use any and i know your car is a lot newer than mine. This might not be connected though. Link to comment Share on other sites More sharing options...
Durrsaku Posted November 8, 2005 Report Share Posted November 8, 2005 Your driving style could affect it too: heavy foot/light foot? Check for any oil leaks:/crank seals/turbo seals/valve cover gasket etc. Excessively clogged injectors? But then this will result in low compression. Link to comment Share on other sites More sharing options...
Sparky Posted November 8, 2005 Author Report Share Posted November 8, 2005 No oil leaks anywhere - or at least none that I can see. I do push it. I'm not quite as bad as Milo made out, but it doesn't hang about. It drives well with no performance issues that I can detect. Link to comment Share on other sites More sharing options...
Milo Posted November 8, 2005 Report Share Posted November 8, 2005 Me? I never said a thing To be honest I don't think you've got a problem. All diesels, mine included, seem to like to clear their tubes first thing when you start them. If it was chucking smoke out all the time when you were driving, or excessive smoke everytime you accelerated I would be worried. Get Audi to check it over but I wouldn't be overly concerned Link to comment Share on other sites More sharing options...
Chav Posted November 8, 2005 Report Share Posted November 8, 2005 [ QUOTE ] When I leave the house in the morning, I often put my window down to clear any rain-water on the side windows, and when reversing, I really can smell the car. It appears to really chuck some crap out, and sometimes I can see white smoke. [/ QUOTE ] No comment. Link to comment Share on other sites More sharing options...
