M25 variable speed limit
dq1
Well I think you could argue the case if you were "caught" doing 50 that you were following the signs. As long as the variable speed signs were the mandatory ones with a circle around them rather than the adivisory ones with the flashing lights.
In answer to your question 40 to be safe but you would have a case if you were going 50. But I don't know the letter of the law I am just going on common sense approach - but when has that ever happened?
