Re map
IzzaB
Hi Guys
Newbie here with a question. I've been the happy owner of an A3 1.8TQS (2001 facelift) for 18 months and think it is time to re map. I've been told that the ECU will have to be removed and just want to check if that's right? I thought it could be done via serial port, but am a bit of a techno duffer! Any advice/tips would be welcome. Cheers!
You can get have the car flashed through the OBD port - or if you want a custom remap, your ECU will get replaced with an emulator to get the best from your car and then the file created from that will get flashed to your ECU.
I would make sure the car gets tested before a flash/remap.
you should be up around 215bhp to 230bhp depending on the spec of the car, with 250+ft-lb
Hi Guys
Yes this is correct. The 1.8T VAG cars are equipped with 2 different ECU's. One can be be communicated with via OBD, some need to be tuned off the car. Perfectly fine, similar process but bypassng the OBD connector laugh.gif
Regards
Will
