Loose brake pedal cover
Ecosse79
Well, what's to say?
Tight fit = lube, something to do with friction. Dare I suggest putting it on a radiator for an hour and a little bit of Fairy liquid.
The radiator will warm up the cover and plastic /rubber shell and the Fairy liquid will allow you some extra lube- and help keep Mr. B4stard Friction away.
If you have to use serious muscle sportifs2.gif, you're doing it wrong 169144-ok.gif
Had exactly the same problem a couple of months ago. Use a small amount of washing up liquid and a lot of patience. The rubber lug on the back of the pedal needs to sit properly in the hole in the middle of the brake pedal or it will come off again.
Don't use any oil based lubricant or it will degrade the rubber.
HTH
