sween Posted November 9, 2005 Report Share Posted November 9, 2005 Has anyone had any probs with the radio/cd/sat nav head unit reception? Mine is intermittent, I suspect the ariel and every time I get near the stealers to get them to check it, it starts working again and they won't look twice at it until it isn't working. This is driving me mad as it decides not to work when I've got a long journey to do. Help me, before I hammer it to death!!!!!!!!! Link to comment Share on other sites More sharing options...
PetrolDave Posted November 10, 2005 Report Share Posted November 10, 2005 What unit do you have (RNS-D or RNS-E), and what's the model and year of your car? Link to comment Share on other sites More sharing options...
sween Posted November 10, 2005 Author Report Share Posted November 10, 2005 Not sure what model the navi is, how can I tell the difference? I bought the car SH (private). It is a 2004 model s line Link to comment Share on other sites More sharing options...
Daz Posted November 10, 2005 Report Share Posted November 10, 2005 Here you are. These are the 2 different Nav systems. Link to comment Share on other sites More sharing options...
sween Posted November 10, 2005 Author Report Share Posted November 10, 2005 Its the RNS-D. Link to comment Share on other sites More sharing options...
PetrolDave Posted November 11, 2005 Report Share Posted November 11, 2005 Poor reception normally means there's a problem with the diversity antenna system. A4's have multiple aerials integrated into the glass on both saloon and avant (which do you have?), these feed into an aerial amplifier and then there's 2 connections to the RNS-D. If you have the TV option there are 2 aerial amplifiers with 2 signals to the RNS-D and 4 to the TV tuner. You should also have a roof mounted "shark fin" which is the GPS antenna (and GSM antenna). Most commonly one of the antenna connectors isn't fully pushed home on the back of the RNS-D. Worst likely case is that the antenna amplifier has an intermittent connection either internally or on one of it's connectors - that's hidden behind the trim in the boot area. I'd try sliding the RNS-D out (you'll need a set of 4 removal tools) and checking the antenna connectors. Link to comment Share on other sites More sharing options...
