Quiet PC case?
Ari
A friend of mine built me a really nice PC a year or two ago, and it's been first class.
Only snag is it's got a really noisy fan (or fans). Anyway, I've mentioned this to him and he's going to re case it for me plus add some additional USB ports at the same time.
So what is the best case to get and where from?
Any ideas or suggestions?
i personally like the coolermaster ones.
case helps but really , its the components in it.
psu, fans, graphics cards and more importantly how much heat the chip makes, and how much heat you have to get rid of.
a cooler running chip makes it easier for a quieter running system, as less heat to get rid of.
to be pedantic Ari, it's not the case that is noisy but the fans in it.
You could keep the same case and replace the fans - silenX, panaflo and pabst are all quiet [pabst are bloody expensive though!] as well as a quieter psu.
then when you get into this case you could throw sound-dampening foam into your case, replase the fan on your cpu cooler......quiet pcs are an expensive [but rewarding!] game to get into.
id agree if your going to want to try and get a quiet pc, then make sure you have the budget to chase those noises.
ive got quiet running fans on 7v not 12volt.
sound deadening
zalman chip coolers
zalman heatseks on graphics cards instead of fans
selected hard drives for silent ones
selected psu for silence and investigated what motherboards had an extra onboard fan and which didnt
round cables for better airflow, ie fans can run slower.
switchable fans etc
the list is endless.
Sound deadening for the case, rubber-mount all drives...
Best one I ever saw was a PC which was totally watercooled, CPU, chipset, GPU, the lot. - Water pipes went out the back of the PC, into the next room where the pump and radiator were. Good PSUs can be virtually silent, so the only noise it made was the quiet drive ticking every now and then.
I've ordered a Antec SLK3700-BQE Case, 350W PSU and Acoustic Material - £75.00 (£88.13 inc VAT)
Near the bottom of the page HERE
The Antec SLK3700-BQE (Black Quiet Edition) is a case that has been designed to help users build a very quiet PC for a great price! This case is supplied with a quiet 350W Antec PSU (click here for technical information), one 120mm quiet Antec fan and a 17 piece acoustic material kit from the manufactures of the excellent AcoustiPack - Acousti Products.
The acoustic material kit is a pre-cut set of acoustic materials especially designed for the Antec SLK3700-BQE tower case. The pre-cut AcoustiPack™ for the BQE adds to the quiet features built in to this case to help create a case that will run almost silently along with other quiet components.
The kit consists of 5 acoustic foam blocks, and 11 shaped pieces of acoustic composite. The kit also contains an additional washable dust filter - which improves the air filtration on the existing air filter in the front of the case.
Some of the foam blocks are optional depending on how many internal components are installed. The acoustic foam pieces are designed to occupy unused void space inside the case, and serve to reduce internal case volume and absorb internal operational noise. For example, fitting of one of the large blocks supplied into the void area under the HDD cage (which is rotated 90° to 'normal' drive cage orientation) serves to 'duct' airflow from the front of the case through the HDD cage, therefore aiding HDD cooling by increasing air flow velocity.
Antec SLK3700-BQE - Features
1. Supplied with a Antec 350W quiet PSU and one 120mm Antec case fan
2. Accommodates two 120mm case fans (one supplied), one front, one rear
3. Anti-vibration rubber mountings for HDDs
4. Accessible front USB 2.0 ports
5. Supplied with a 17 piece sound-proofing kit
6. Sound-proofing kit includes a washable air filter!
Specifications
Model Antec SLK3700-BQE
Manufacturer Antec & Acousti Products
120mm Case fan spec 1200 RPM, 38.94 CFM, 24.86 db(A)
Weight 13.00 kg
Outer case dimensions 210 mm wide, 470 mm high, 465 mm deep
Supported motherboards Full-size ATX, AT and MicroATX
3½ inch drive bays 2 accessible plus 4 internal
5¼ inch drive bays 4 accessible
Not the prettiest of cases, but where my PC lives it can't really be seen, and it seems good value for what it offers. Should have it by the end of the week all being well. 169144-ok.gif
Should be fine Ari. 120mm fans are quieter as the can spin slowly but still shift a lot of air in and out of the case. Some are still a little rattly just see what its like, replacement fans are easy to find and fit in most cases.
About the quietes PC you can get is the new GTX cases. They only have 2 fans, one on the power supply and one in the front of the case. The one in the front of the case blows air back through the case, through a heat sink cooling the processor, over the graphics card and straight out of a mesh at the back of the case. I've got this config in my Dell 5000 and it is virtually silent, when I first showed it to my Dad he wouldn't believe that it was switched on. He has one of his own now. grin.gif
Well it's certainly quiet. Completely silent in fact!!!
Mainly because as soon as the power was connected the PSU exploded!! blush.gifblush.gifblush.gif
A new PSU was used but it's an ordinary one, not a super quiet one, so despite the new case and soundproofing etc it's not much quieter than before (but blimmin heavy!!!)
Have emailed the manufacturer to ask them to change it for a non exploding type so we'll see... crazy.gif
Was it set to 110v and not 240v?
Some of them have a little switch on the back of the PSU, we keep reminding all the Americans at trade shows about this and we still end up with 1 or 2 systems needing a new PSU where they've forgotten to flip it.
Ok so it's got the proper PSU in there now (top service quietpc.com, thanks!)
And Wow!
It was quieter with the new case but dodgy old standard type PSU, but with the right PSU it's superb! Put it this way, you can hear it, but it's about the same volume that the old one was if you stood outside the room and shut the door!
Seriously, it's that good, I'm well chuffed.
