tintsy Posted November 11, 2005 Report Share Posted November 11, 2005 I have jus got an 20v passat and the clutch is not bitting till nearly at the top, is it possible to adjust it, if not how much of a job is it to changed the clutch. Link to comment Share on other sites More sharing options...
paffat Posted November 12, 2005 Report Share Posted November 12, 2005 not a clue about adjustment, prob hydrolic, so self adjusting, you will have to check but had my head under my 1.8 20v today and gear box removal looks a doddle. BE SAFE if attempting diy job. H. Link to comment Share on other sites More sharing options...
mulkbear Posted November 12, 2005 Report Share Posted November 12, 2005 You can not adjust the clutch as it is hydrolic Changing the clutch is not as bad as some cars but a good tool kit is needed and the is a range of torx, spline and allen key bolts and the gear box is mounted like a Rear wheel drive car which is strange Link to comment Share on other sites More sharing options...
tintsy Posted November 13, 2005 Author Report Share Posted November 13, 2005 Thanks for that. I spoke to a mate hows got an Audi A4 with the same motor, He fitted a new clutch because he was like when he got it, with the pedle at the top, when he changed his clutch the pedle was the same, so I wonder are they all like this, My clutch does not slip at all, in any gear ?? Link to comment Share on other sites More sharing options...
karlosthejackal Posted November 13, 2005 Report Share Posted November 13, 2005 Hi what is the mileage on your passat? the clutch on my 20v passat was the same as yours and it had 160,000 miles on it when i sold it, and I am pretty sure it was the original clutch. Link to comment Share on other sites More sharing options...
tintsy Posted November 14, 2005 Author Report Share Posted November 14, 2005 its done 87000, thanks Link to comment Share on other sites More sharing options...
