20v remote locking range
20valver
I have got trouble with my '97 1.8 20 SE locking/unlocking via the remote keyfob.
It will only lock when key fob is right up to the car.
Keyfob has new batteries and so does the car.
Tried the old reset routine lock, press for couple seconds, unlock with key ect but problem remains. smashfreakB.gif
Any Ideas?
  • 5 months later...
I posted this a few months back and thought I would revive it to see if anyone else has had this problem?
I have seen all the posts for false alarms etc, but mine works fine except how close you need to be to get the car to lock/unlock.
  • 3 weeks later...
Just in case anyone is interested.
Vag com could not talk to the unit that runs the remote locking. Another mate of mine has a diags kit for all type of cars (can't remember the name but cost him about £3k) and that had the same result.
Tonight we decided to take the unit out (what else do you do at work! grin.gif ) and took out the control unit. All looked ok apart from the contacts needed a light clean and the pcb inside looked like it had at some point condesation on it.
Resoldered the pcb where the reciever sits to make sure there were no dry joints gave the pcb a little clean with pcb cleaner.
Put the unit back in, checked the wiring is ok and it has started locking at a further distance. Forgot my other key with a new battery in it (the one I have at work has died through testing the locking!) so will check the range when I get home in the morning.
