What type of S8 engine oil?
stevebower
Sorry - definite 'newby' question here:
What sort of engine oil should I put it? I think the car is set up for variable service intervals (how can I tell? the monitor says 10k to go), but the handbook only mentions a spec, not Synthetic etc. As there will be some time before the service, I want to get the right stuff in, but not pay stealer prices.
Ta, Steve
For AVS you will need this, or equivalent from other than Castrol...
Lifted from Audi website....
One of the key components of the AVS system is the engineering and technology of Audi engines including areas such as precise machining of components, honing of cylinder bores and closer bearing tolerances.
This is allied with the use of advanced formulation Long Life oils such as Castrol SLX OW30 Long Life 2., which have been specially formulated for Audi.
It's approximately £9.00 a litre from Halfords... 169144-ok.gifYou can get the specc'd oil cheaper on the web but in much larger quantities. frown.gif Have been looking at the latest Mobil 1 Long-Life oil as a subsitute but need to check its compliance to Audi spec...the original Mobil 1 didn't.
Prolly wrong of me I know.... I have always left this to the stealer. Mine does not appear to use oil (unless there is a leak!) This 1L every 1000 is quite worrying!
Anyways, rightly or wrongly the Audi Stealer I use puts in Castrol GTX Magna-Tec..............
Must get the manual out and have a squint.......
Laffer.
Also on the topic of AVS, I think this might be another problem waiting to happen, like the failing transmission issues. I really would ignore this and change oil and filter every 10K max if I were you guys with this, extended service intervals only end up meaning one thing, reduced engine life!!
Bill was for belt only (I think). No advice that tensioners needed. Water pump checked - no leaks, bearings ok.
AVS is Audi Variable Service - my car was mainly on motorways, so service intervals were longer. The car can be set for AVS or fixed.
Ric Woods is www.ricwood.com. I hope he's ok - the gearbox leak needs doing next. It's good to save a few bob, but I really want the car looking after properly.
