CLIMATE CONTROL/AIR CON NOT WORKING
paffat
Hi, My troubled passat 2000 1.8t sport has an air con problem, after re-gassing and changing the cabin filter I was advised to change the 4 pin sender unit in the condensor. This has all been done and re-gassed again but no luck. I can power up the compressor manualy but no joy therwise. Is there a common fault with this model any help would be great. Thanks.
Hi,
Had to sort my Saab Climate this summer and trawled round several "aircon specialists" in our big town. Several had a guess and I wasted a bit of money and lots of time before finding a good Saab indy with the right diagnostics and willing to give a g'tee that his work would fix it.
Mine was the relay on the compressor and a new pump was the best way. Not cheap. Yurs sounds like a control issue which might be easier. I'd get it diagnosed by someone with the right VW gear. Then get that commitment from them that their diagnosis is correct and will fix the problem if you give them the job. Otherwise you can end up paying a fortune for someone to swap parts.
Dick
