New Torsen 40/60 torque split
peterb
Humm, would be nice wouldn't it? I think the Torsen is integrated into the gearbox on the Tip models (if I remember rightly) and the 5 HP 24A isn't likely to be made available with it, in fact the upcoming S8 with 60/40 split might not even be the usual 6 HP 26A for the same reason.
As far as I can tell, from ELSA, the Torsen module is mounted in its own housing, bolted onto the tail of the gearbox. It can be removed and replaced with the gearbox in situ.
Ah, I see. Looking at it, yes it does look to be attached right on the end of the gearbox, but it is part of the assembly ZF supply; as in the gearbox info sheet (PDF). I'm not sure if the new S8 gearbox will be a 6 HP 26A with a different Torsen bolted on, or a totally new gearbox.
Yes, but delving inside, the actual functional part of the Torsen is a small 'canister'. If the dimensions of this part are unchanged, then it ought to be possible to swap.
This torsen module (Part No. 01L 409 751) is the same part used in the A8/S8 from 94 to 03 and A6/S6/RS6 from 98 to 05.
169144-ok.gif That would be very neat.
