R32 Aluminium tax disk holder sticky bits
s4dreamer
Having replaced the tax disk twice now, my aluminium tax disk holder no longer sticks properly to the windscreen.
I seem to remember that when I got it, the note in the package said you could order them, but I've lost the note and record of the company I bought it from.
What have the rest of you done ?
Aye, plus my local A1 Autostores does replacement packs of 6 for about 99p.
I have to ask, is you Ali Tax Disk holder not one with the wee allen grub screews where the back screws off so the bit stuck to the window nevers needs to be taken off the glass?
Also, you could simply apply some double side tape to the sides of the wee rubber sticky bits - if you have some double sided tape!
Yep, it's one of those with the grub screws, but when I first stuck it on, I put it too low, so after much faffing with the allen key, I ended up taking it off the screen because I couldn't get the screws back in. D'oh!
I guess I could have used some double sided tape, but the sticky pads are quite thick, which helps deal (partially) with the curve of the windscreen.
Now I've bought a pack of 30, I don't have to worry about how many times I remove it and stick it back on smile.gif
But if you stick it back on, stick it on a tad higher up so you can remove the back and not take it off each time.
Was this another freebie which originally came with all R's? (along with the pen, umbrella and keyring I never got with mine... frown.gif)
Hi chri5, And I thought I was the only one who mounted theirs on the dash! Watch out with the Blue Tac though cos it can stain. My reason was having a rebellious nature and a hatred of all authority telling me where I should stick my compulsory licence. In previous cars I have always stuck the licence centrally behind the rear view mirror but the Mk5 Golf has rain sensors etc plus I have a (very tasteful) graded sky blue windscreen strip.
....That's been my expectation but my car has been seen by plenty of 'Feds' and one has even driven it without any comment about it!! However, sooner or later I expect one will mention it and I'll be ready for it. Mine is bottom left corner. I had my tax disc centred behind rear view mirror on my BMW for how many years? - Over 10! Good advice though 169144-ok.gif
