Timing belt change
tintsy
Make sure you do the belt becasue Ive just took the head off the same car and engine as yours because the teeth on the belt had come of and it now requires a complete engine. Bent all the valves and guides and the pistons are knackered because the valves hit the pistons. It was only 5 years old and only done 70K. VW now recommend that all engines have the cambelt changed every 4 years regardless of mileage.
  • 3 weeks later...
