[Audi A3/S3] Brake lights failed
neo283
All of the brake lights have failed on my A3. Pretty certain it's the contact switch behind the brake pedal as there is a distinct 'hissing' sound when I press it. Funnily enough, the switch was replaced recently and is only 3 months old.
Could the problem be anything else? I changed all the brakes & pads a couple of weekes ago, could I have knackered something when I did that? Can't see how I did!
The stereo is starting to play up again too!!! Taking ages to fire up. Grr, just when I need to sell it!!!!! SAUER0421.GIF
  • 3 weeks later...
Yup,
Was the brake light switch behind the brake pedal as suspected. Cost £38 to fix at my local AVW specialist. Part is £12ish and it's 30 mins work with the right tools. Can't complain!
Good luck and keep checking your rear view mirror till it's fixed!!!
