ashleyminors Posted November 19, 2005 Report Share Posted November 19, 2005 My A4 didn't come with an armrest and it's been driving me mad. So I bought one from VAGParts. I've managed to fit the bracket etc (which was quite an achievement in itself for me) but I'm left with the challenge of cutting the plastic centre console trim VAGParts website says that the plastic is probably marked underneath to show you where to cut, but you cant see this without removing the centre console, something which I just don't fancy attempting because its looks a nightmare. So, any ideas as to where I need to cut? I have a pretty rough idea but I'm cutting into the trim so have probably only got one go at it and don’t want to mess it up! Perhaps if anyone has got any photos of their armrest so I can see where I need to start would be helpful or any other ideas. Link to comment Share on other sites More sharing options...
UBM Posted November 19, 2005 Report Share Posted November 19, 2005 Can you run your finger underneath in the hole and find the raised plastic indicating where to cut? Link to comment Share on other sites More sharing options...
UBM Posted November 19, 2005 Report Share Posted November 19, 2005 I'll get a pic for you! Link to comment Share on other sites More sharing options...
UBM Posted November 19, 2005 Report Share Posted November 19, 2005 I'd say like this : Link to comment Share on other sites More sharing options...
UBM Posted November 19, 2005 Report Share Posted November 19, 2005 from behind... Link to comment Share on other sites More sharing options...
Daz Posted November 19, 2005 Report Share Posted November 19, 2005 Tip - start with a small hole in the middle and gradually work your way out to get the right size hole. Link to comment Share on other sites More sharing options...
ashleyminors Posted November 19, 2005 Author Report Share Posted November 19, 2005 Thanks for the pics, I'll give it a go tomorrow in the daylight. Link to comment Share on other sites More sharing options...
Chrisg Posted November 19, 2005 Report Share Posted November 19, 2005 Think there is a tech article on Audiworld or Audizine actually I've just looked but can't see themBUT i'm sure I've see it somewhere complete with piccies Link to comment Share on other sites More sharing options...
ashleyminors Posted November 19, 2005 Author Report Share Posted November 19, 2005 I've got nothing else to do all evening so I'll have a good look. Cheers. Link to comment Share on other sites More sharing options...
Bluedan Posted January 31, 2006 Report Share Posted January 31, 2006 UBM could you do me a favour? Could you measure the distances as shown on the attachments? Does the armrest sit centrally in the middle, with equal gap each side? Many thanks Link to comment Share on other sites More sharing options...
Biscuits Posted January 31, 2006 Report Share Posted January 31, 2006 Quick question..... how'd you get the bracket mounted without a hole ??? Link to comment Share on other sites More sharing options...
Bluedan Posted January 31, 2006 Report Share Posted January 31, 2006 I am trying to cut the hole, but in the correct place. I have the technical drawing from the Audi Workshop manual which I can put on here if anyone wants, but I made a template from it and layed it over, and one of the dimensions is incorrect, which would leave a big visible hole in the centre console, so I'm glad I did a trial run first! So I wanted to know where the surround sits, as per the above diagram, that way I can locate it properly. Link to comment Share on other sites More sharing options...
Biscuits Posted January 31, 2006 Report Share Posted January 31, 2006 Good luck Bluedan, let us know how you get on with pics... it's a mod high on my list Link to comment Share on other sites More sharing options...
UBM Posted January 31, 2006 Report Share Posted January 31, 2006 Dan - I've got to go to ante-natal class four tonight. I'll measure it up when we get back about 10-30 mate! Link to comment Share on other sites More sharing options...
Kaskat Posted January 31, 2006 Report Share Posted January 31, 2006 When I fitted my armrest there was pattern made from card that you stuck down to the centre consule before you cut it out (I would not have attempted cutting without that template), I've looked for the template in the garage but alas its gone. If I were you I would pop into an Audi dealership and ask if you can have a photocopy of a template from stock, you never know they might be helpfull Link to comment Share on other sites More sharing options...
ashleyminors Posted February 1, 2006 Author Report Share Posted February 1, 2006 I fitted mine in the end thanks to the pics from UBM. I cut out a piece of paper the same shape as the bottom of the armrest for a guide just so I could position it in roughly the same place as the pics above. I cut a small hole in the middle of the cosole/where the armrest was to go(with a jigsaw! ) and slowly worked my way to the outside until I could fit the bracket through. As the actual armrest overlaps the hole there is no need to cut a perfect shape. As long as you can fit the bracket through. The armrest sits flush on top of the console and you cannot tell. Looks identical to the pics of other factory fitted armrests. The truth is there is a horrible shaped hole underneath but no one is going to ever see that (I hope.) Link to comment Share on other sites More sharing options...
Bluedan Posted February 1, 2006 Report Share Posted February 1, 2006 I have this diagram from the Audi workshop manuals. The problem is dimension "C" is totally wrong and will leave a big hole in the centre console which will be visible, after the armrest is fitted!! This therefore doesn't fill me with confidence, so wanted a more practical "Do-it-yourself" approach! Does this picture look generally correct though? A - 9mm B - 5mm C - 48mm (Wrong!) D - 31mm E - 15mm F - 16mm G - 9mm H - 43mm Link to comment Share on other sites More sharing options...
Biscuits Posted February 1, 2006 Report Share Posted February 1, 2006 Are the parts and installation the same for the B6 and B7 A4/S4 ? P. Link to comment Share on other sites More sharing options...
Chav Posted February 1, 2006 Report Share Posted February 1, 2006 New armrest came out in 2005.... it has a different lever mechanism for raising/lowering, so will have a diff. part number, but either armrest will fit Link to comment Share on other sites More sharing options...
UBM Posted February 1, 2006 Report Share Posted February 1, 2006 I;m on it - can you wait till tonight for your measurements... Link to comment Share on other sites More sharing options...
Bluedan Posted February 1, 2006 Report Share Posted February 1, 2006 Yes, no problem. Link to comment Share on other sites More sharing options...
Nelson_R32 Posted February 1, 2006 Report Share Posted February 1, 2006 I have the template at work, I can post a 'tracing' of it to people if they want it? PM me for my email address... Link to comment Share on other sites More sharing options...
Bluedan Posted February 1, 2006 Report Share Posted February 1, 2006 I'll do a proper install guide with pictures once I get round to it! But no idea how to paste it on here! Link to comment Share on other sites More sharing options...
Biscuits Posted February 1, 2006 Report Share Posted February 1, 2006 I've looked on VAGParts but can't find the armrests... eBay have only got patent part copies.... Link to comment Share on other sites More sharing options...
Chav Posted February 1, 2006 Report Share Posted February 1, 2006 [ QUOTE ] I've looked on VAGParts but can't find the armrests... eBay have only got patent part copies.... [/ QUOTE ] Here you go, mate! vagparts armrests linky Link to comment Share on other sites More sharing options...
