Mk V R32 vs A3 3.2 Quattro vs Passat 3.2 4motion
Heppubansan
Ok, all these cars are based on the MKV chassis, all weigh roughly the same (yes even the passat, due to aluminium components), and all use the same driveline/engine/transmission.
Keeping the spec btw the 3 the same and with golf and a3 in 5dr form with DSG - the golf is 25k-ish and Audi is 26.5k-ish, passat comes as standard with DSG and sports suspension and is also 25k-ish. BUT on drivethedeal.com (and other brokers sites) you can get a 2k discount on both the a3 and the passat - making a3 1k cheaper than the Golf and the Passat 2k cheaper. What do you think? Im leaning towards the Passat - at about 22.5k thats a hell of a lot of car for the money, and its by far the cheapest to insure.... decisions...
Fair enough. If it's just down to figures then what you've quoted do seem good deals, but there will be a difference in depreciation for sure.
You're unlikely to get any discount on an R32 for the forseeable future, but that also means residuals are going to be strong for a long time too.
Are the specs similar on each of them?
I'd personally go for the R.
No Robin, the V6 4Mo was the first Golf to use the 4Motion system. Before that, you've got to hark back to the Mk2 Golf Syncro - remember that one..? 1.8 lump with as much thought about performance as a bag of lard in hot weather.
Ideally, the Mk5 Anniversary GTI will be 500 limited run, 240 bhp 2.0 TFSI with 4Mo. Shouldn't kill R32 sales due to the limited run, but you never know with VW...
